Oneplus 7T Pro 5G Mclaren (T-Mobile) via OnePlus 7T Pro 5G
  1. Great Gatsby , via OnePlus 7T Pro 5G , Jun 24, 2021 :
    Hey guys was wondering if any of you have been experiencing issues with the 90Hz panel on the 7T Pro McLaren. After updating to the latest update I've noticed that every now and then my screen lags really bad. Probably lower than 60HZ. It takes about 2 minutes before the screen looks fluid again. Anyone experiencing the same issues?
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Jun 24, 2021
    Dresa91 , Jun 24, 2021 :
    About what update version are you Talking?
    And what version did you use before the update?
  3. Great Gatsby , via OnePlus 7T Pro 5G , Jun 24, 2021 :
    I don't remember the actual version, bit I still had the old Oxygen OS and now it's the new one that looks like Samsungs one ui
  4. Dresa91
    User of the Year 2016; Most Active User 2020 Jun 25, 2021
    Dresa91 , Jun 25, 2021 :
    Okay.
    So you moved from A10 to A11.
    Did you clear cache in recovery?
    What about performing a factor reset? It is always recommended after a major update
