4
Oneplus 7t pro Charging Issue
  1. A1589544203648
    Cupcake May 22, 2020
    A1589544203648 , May 22, 2020 :
    I have the same issue with my OnePlus 7T and I don't know what should I do maybe this is a software issue. If it is then company should do something about is
    ( I have tried different adapter, different charging point and took a proper care of my cable)
  2. Sarpanch_Rohit
    Cupcake May 25, 2020
    Sarpanch_Rohit , May 25, 2020 :
    I have Oneplus 7t I am facing the same problem I have to restart my device to get it charge again everytime Battery come under 30-40 Percent it Happens.
    Service team Told me to clear Catch Data Noting happen Factory reset also didn't work , They told me that they will do the Remote Flashing after that also they could not repair My device
    They will not even Replace The device even if they not able to repair it.
  3. Nagaraju RJ
    Cupcake May 28, 2020
  4. hemum90
    Cupcake Jun 2, 2020
    hemum90 , via OnePlus 7T , Jun 2, 2020 :
    OnePlus 7t not charging... after restart the mobile then it start working. and I have another issue. not getting calls as well. after restart able to do call and receive the calls.
  5. Sarpanch_Rohit
    Cupcake Jun 2, 2020
    Sarpanch_Rohit , via OnePlus 7T , Jun 2, 2020 :
    From few days I am charging my mobile with the USB which I got with the mobile and it is working fine.
    When I was facing this issue I was charging my mobile with the USB I purchased from the OnePlus site 150cm cable.
    I think when our USB get any damage it give spark to the mobile which allow it to stop Charging and when we restart it get reset.
    So I suggest to buy a New Cable.
  6. hemum90
    Cupcake Jun 2, 2020
    there no issues with usb cable. what is the point of cable. there issue should be device side. because when u restart the mobile then only start working.
    I have tried multiple oneplus usb cables same issue.
  7. Suraj18
    Cupcake Jun 5, 2020
    Suraj18 , Jun 5, 2020 :
    I have the same issue with my OnePlus 7T, suddenly the charging stops but at the same time; if I plug-in OnePlus 6 or 3T with the same charger it works without any issue on those phones. To get 7T charge I need to restart it, it is happening with me for approximately 3 weeks now and 2 days in succession. I am on 10.3.2 but I do not know if 10.3.3(OTA didn't receive yet) addressed this issue or not. Attaching phone information.
  8. naveen.bhardwaj
    Cupcake Jun 21, 2020
    naveen.bhardwaj , via OnePlus 7T , Jun 21, 2020 :
    Guys i think i might have found a workaround to this.
    It has been working for me for the past 5 days.
    Try this, whenever you are connecting your charger to the phone, quickly go and enable the OTG from notification/quick settings (within 5 seconds).
    In my experience, as soon you connect the charger, the charging starts but after 5-10 seconds it used to stop charging and then i had to restart the phone.
    With this workaround it continues to charge, and work as expected.
  9. Y1577528595362
    Eclair Jun 21, 2020
  10. vishwasaalok
    Cupcake Jun 23, 2020
  11. Sarpanch_Rohit
    Cupcake Jun 30, 2020
    Sarpanch_Rohit , via OnePlus 7T , Jun 30, 2020 :
    I was also facing this problem but when i change the USB cord my problem solved and whenever I use the old USB cable I face the same problem again. I have posted 2-3 times in this Forum you can check . New USB cable solved my problem
    Try using someone else cable for sometime if you don't face same problem then you need to change USB cable.
