13
Oneplus 7T Pro laggy and slow after OxygenOS 11 update
  1. Danielsou
    Cupcake Mar 25, 2021
    Danielsou , Mar 25, 2021 :
    Am I the only one whose OnePlus 7T Pro Is really laggy and slow after updating to new software ? Is there something I can do to reduce those lags. I never got these lags on the previous OS. Thanks
  2. Tokolozi
    Most Original Avatar Mar 25, 2021
    Tokolozi , Mar 25, 2021 :
    Check if there isn't some app using excessive battery.
    Additionally, while not always fun. I recommend making a backup and resetting your phone after a major version update. It solves almost all issues.
  3. Tokher
    Donut Mar 25, 2021
    Tokher , Mar 25, 2021 :
  4. dmr94
    Donut Mar 26, 2021
    dmr94 , Mar 26, 2021 :
    I thought i was the only one... Feels a bit more laggy when opening some apps but not to the extreme either
    Paul_9.9_, Soytheist and Danielsou like this.
  5. ShoaibBhutia
    Donut Mar 26, 2021
    ShoaibBhutia , via OnePlus 7T , Mar 26, 2021 :
    Nope you're not the only one. When you slide down the status bar while gaming it feels like 24fps transition. Also while using chrome and watching movies.
    x_uttu_x, Paul_9.9_, Y.Singh and 4 others like this.
  6. dmr94
    Donut Mar 26, 2021
    I feel that the sound after the update to Android 11 is less, also the "Vivid" screen calibration does not work as before.
    Paul_9.9_ likes this.
  7. x_uttu_x
    Cupcake Mar 28, 2021
    x_uttu_x , Mar 28, 2021 :
    Same every app feels slow. Pls recommend something to fix it. Thinking of going back to oxygen os 10.3
    ccalvarez and Ionita_Florian like this.
  8. OnePlus 7
  9. AlvarezPt
    Cupcake Apr 1, 2021
    AlvarezPt , Apr 1, 2021 :
    Same here, what the hell. And its not just a bit, it's clear some apps do take longer to open, scroll through things slower, etc.. Is this Apple now?
    Ionita_Florian likes this.
  10. J1617864843782
    Cupcake Apr 8, 2021
    J1617864843782 , Apr 8, 2021 :
    Same here on my 7T. after a reboot it it fine for a while. After a while scrolling in every app is slow and laggy. This wasn't the case with android 10.
  11. bklash3
    Cupcake Apr 12, 2021
    bklash3 , Apr 12, 2021 :
    Yes, this, all around frame rate drops, stuttering, bad battery life, wonky auto brightness and sometimes dropping wifi. With 10 it was the smoothest phone I have ever seen and felt amazing everyday. Now, not so much, clearly not as enjoyable. We need a fix. Till then going back to 10. If only there was a way without loosing all the data.
  12. U1617206295051
    Cupcake Apr 13, 2021
    U1617206295051 , Apr 13, 2021 :
    I't must be the "new "(for oneplus) apples strategy to make us bay the new phone.
    My 7 pro feels like a brick sins the update
  13. McLarenMania
    Gingerbread Apr 15, 2021
  14. 51NGH
    Froyo Apr 15, 2021
    51NGH , via OnePlus 7T Pro , Apr 15, 2021 :
    I felt the same hence I unlocked the bootloader and downgraded to 10.3.8 and relocked the bootloader. Everything's fine and it feels way better on Android 10.
  15. tany93
    Cupcake Apr 18, 2021
    tany93 , via OnePlus 7T , Apr 18, 2021 :
    Hi, I've experiencing the same issues and I've seen that restarting the phone fixes the issue for a while. However, it was extremely annoying to restart the phone every time it happened so I've investigated a bit more to try to figure out if it's a real performance issue or is just the screen turning the frame rate down.
    Long story short, if I switch the frame rate in the settings to 60fps and then back to 90 fps it does the trick for me.
  16. F1619125148725 , via OnePlus 7 Pro T-Mobile , Apr 23, 2021 :
    So I recently have been having some issues with my 7 Pro after the Android 11 update: the screen refresh rate has tanked, it is very laggy, and some things take a bit longer to load. I've heard other people complain about the same thing as well. I have a remedy to recommend that may help some people tolerate this issue (sort of). If you go to the Developer Settings (if yours is not open, go to "about phone" and tap "build number" rapidly until you see the text that reads "congrats, you are now a Developer) or search for "remove animations". This will remove transition animations. It does not solve the slow and glitchy issues, but it at least hides the laggy refresh rates. Of course this is all personal preference and not everyone may find it as accommodating as I did
  17. rajatsingh30
    Cupcake Apr 25, 2021
    rajatsingh30 , Apr 25, 2021 :
    It is really really slow for me now.. completely useless after the upgrade.
  18. Ionita_Florian
    Ionita_Florian , via OnePlus 7T Pro , Apr 25, 2021 :
    Same here. Scrolling through apps is somehow limited at some maximum speed. In Oxigen OS 10 scrolling speed was way faster.
    Also screen touch response feel slower.
    It's just feel like a slower phone. I choose this phone for his speed...
    Please make it like O OS10 again
  19. R3cycl0r
    Gingerbread Apr 26, 2021
    R3cycl0r , Apr 26, 2021 :
    I'm here for the same.l issue, but only now I notice that my screen refresh rate was set to 60hz (I left it at 90hz on Oxy10 anyway, it somehow changed on itself), so I'm switching now back to 90hz (also the 'auto' mode is not present anymore, only 60 or 90). I don't think that for all of you was the same, also because other people already checked their refresh setting, but for these minutes everything is back to normal. I will update here if something changes anyway
  20. I1555038140848
    Cupcake Apr 26, 2021
    I1555038140848 , Apr 26, 2021 :
    OnePlus 7T owner here -
    1. After updating to Oxy11 my phone's face unlock isn't responding like it used to; now it takes about 5 seconds to do it if I'm lucky.
    2. The display. before the update when I used to walk outside in the sun and I would see everything on the screen after I increased the brightness all the way up. Now after the update I barely see the screen even after I increase the brightness all the way up.
    3. When gaming, after the update there is a noticeable lag, like a hiccup or stutter. really annoying.
    I have never dropped my phone (always in a case) and have never gotten it wet (phone is almost like new).
    OnePlus, this is very disappointing...
