9
OnePlus 7T Pro McLaren GPS lag
  1. G1572469583021
    Gingerbread Feb 7, 2020
    G1572469583021 , Feb 7, 2020 :
    sounds like a lemon I would call T-Mobile to get a replacement. because it worked for me and so did the update.
    #61
  2. bobsta
    Honeycomb Feb 7, 2020
    bobsta , via OnePlus 7T Pro , Feb 7, 2020 :
    Ah - I don't have the 5G variant of the McLaren handset - just the 4G one that is sold in Europe.
    #62
  3. G1572469583021
    okay well that one hasn't gotten the update yet hopefully that will get the updated next week or so to fix that issue. it looks like one plus did a hotfix for T-Mobile's variant probably because T-Mobile asked.
    #63
  4. Rally_wrex
    Cupcake Feb 7, 2020
    Rally_wrex , Feb 7, 2020 :
    if anyone hasn't tried it yet, I was able to solve my GPS lag by setting the preferred network type to 2G/3G/LTE since 5G seems to be the problem. Settings > Wi-Fi & Internet > SIM & Network > change preferred network type to 2G/3G/LTE
    #64
  5. G1572469583021
    if you have the 5g you have TMobile and they sent it an update that fixed it on 5g. mine worked on 5g.
    #65
  6. Q1578068293537
    Donut Feb 11, 2020
    #66
  7. G1572469583021
    Gingerbread Feb 11, 2020
    G1572469583021 , Feb 11, 2020 :
    I would try to factory data reset then. mine was working after the update the only reason I did a factory data reset was because of battery life which now my battery life is doing much better. my GPS works just fine now on 5G
    #67
  8. Pizzarous
    Eclair Feb 11, 2020
    #68
  9. Ziertus
    Froyo Feb 11, 2020
    Ziertus , Feb 11, 2020 :
    They are still working on bugfixing 5G. It's probably better to stick with 4G if you're looking for reliability.
    #69
  10. Deadwood Hero
    Cupcake Feb 12, 2020
    Deadwood Hero , Feb 12, 2020 :
    not sure if any of you remember when the EVO came out when 4g fist started...but battery drain and signal issues took a few months to fix.. relax
    #70
  11. V1572250538242
    Cupcake May 7, 2020
    #71
  12. carlosveu10
    Cupcake May 9, 2020
    carlosveu10 , May 9, 2020 :
    I also used the GPS Locker kohi click test app to force AGPS data download, waited about 30 minutes, then rebooted a couple of times. So far it's been ok. It sometimes takes a minute to lock, but it's stayed locked. I have two more longclick speed test drives (100+ miles) early this coming week
    #72
