Oneplus 7T Pro Screen Issue
  1. elfenstar
    Cupcake Feb 27, 2020
    elfenstar , Feb 27, 2020 :
    I was wondering if anyone else has this issue where the oled is not flush against the glass and has ripple like effects at the side of the screen. I have it at the top edge of my screen.
  2. NeonX89
    Gingerbread Feb 27, 2020
  3. Liehjan
    Lollipop Feb 27, 2020
    Liehjan , Feb 27, 2020 :
    That's the screen protector, not the OLED screen
  4. NeonX89
  5. Liehjan
    That looks like a glass screen protector on top of the phones own glass..
  6. StopItRawr
    Ice Cream Sandwich Feb 27, 2020
    StopItRawr , Feb 27, 2020 :
    The phone comes with a screen protector applied at the factory.
    You're looking at the edges of it.
    W1583018552379 likes this.
  7. NeonX89
    NeonX89 , via OnePlus Community App , Feb 27, 2020 :
    Whatever it may be, long as the device isn't damaged which it doesn't look damaged, looks just the way its intended separated layer of screen and Glass... If you see a separation of the screen from the frame of the phone then I'd say it's an issue.
    elfenstar likes this.
  8. elfenstar
    Yup same phone, just not the 5G version. I ripped off the annoying feeling plastic protector and went whitestone dome.
    It's noticeable at certain angles in bright light, and prolly happens coz the oled, digitiser, and glass are not laminated together as one like the 7 pro.
    Just wondering how prevalent the issue is.
    NeonX89 likes this.
  9. E1581022147889
    E1581022147889 , Feb 27, 2020 :
    The oled is not laminated to the screen on the 7 pro.
    Watch all teardown u tube movies.
    Also here is not a fault it is the default screenprotector which is not Cristal clear but causes a grain. Remove it an find a beautiful clean bright screen.
  10. adrianrm89
    Cupcake Feb 29, 2020
    adrianrm89 , Feb 29, 2020 :
    Ok. Thx for ur info. But can I add another screen protector without peeling off the existing screen protector?
