3
OnePlus 7T Pro System Lag and UI stutter.
  1. A1577275579996
    Froyo Jul 24, 2020
    A1577275579996 , Jul 24, 2020 :
    Greetings,
    My device appears to be lagging in certain applications, I experience frame drops while scrolling (stutters) and also while navigating through the UI and this happens frequently, apps like chrome, Netflix, YouTube freeze and scrolling in apps like Twitter and reddit doesn't feel smooth, animations aren't fluid as they should be, please look into this.
    ofh, viskr24 and V1571693111537 like this.
  2. V1571693111537
    Cupcake Jul 29, 2020
    V1571693111537 , via OnePlus 7T Pro , Jul 29, 2020 :
    My issue is similar but with the notification bar.sometime when you pull it dow you have to wait seconds for something to happen. Also when you're finally opened the notification bar, it takes ages to open any notification from there. It appears randomly but quite often. It would be great to advise what can be done with this or release a a fix. As I read it is a common problem with the latest software release.
  3. A1577275579996
    Froyo Jul 30, 2020
    A1577275579996 , Jul 30, 2020 :
    Same here, it stutters when I pull it down and it takes a while to open the application when you press on a notification, I have a Samsung device as a secondary phone but it feels smoother, hopefully OnePlus fixes this.
  4. W1570727833149
    Cupcake Aug 3, 2020
    A1577275579996 likes this.
  5. A1577275579996
    Froyo Aug 3, 2020
    A1577275579996 , Aug 3, 2020 :
    For sure.
    W1570727833149 likes this.
  6. viskr24
    Cupcake Oct 25, 2020
    viskr24 , via OnePlus Nord Gray Onyx , Oct 25, 2020 :
    The issue only seems to be appearing when I'm use my keyboard and scroll down the notification bar the second time onwards
    First time its fine
  7. marius_902002
    Donut Jul 30, 2021
    marius_902002 , via OnePlus 7T , Jul 30, 2021 :
    I'm also experiencing stutter of the general UI. It wasn't there before update to android 11 and I hoped it would get fixed with updates, but no. I've had it for a while now, but I also found a way to fix it.
    Sure, the first thing that did the trick was restarting the phone, but that was a time consuming fix
    The second and easiest fix is to go into settings, display and switch between 90hz, 60hz and back to 90hz and then the UI is smooth again.
    Maybe this helps some other people in need.
  8. constant charpentier , via OnePlus 7T , Sep 17, 2021 :
    A faster way to fix this issue is to go to the camera, wait 1 or 2 seconds and go back and it fixes it !
    However this kind of issue is a disgrace and a joke to the OnePlus Moto " never settle" well OnePlus, YOU SETTLED!
    svakshi likes this.
