4
OnePlus 7t pro wifi issue post android 11 update via OnePlus 7T Pro
  1. Vamshi kandakatla , via OnePlus 7T Pro , Mar 31, 2021 :
    After getting official update of android 11 for OnePlus 7t pro, frequently wifi is getting disconnected. Unstable wifi connection.
    If this was issue with router ? Sorry my other phones at home are working fine.
    Need your quick help.
  2. J4t1np4r3kh
    OnePlus Accessory Tester Mar 31, 2021
    J4t1np4r3kh , Mar 31, 2021 :
    Reset the Wi-Fi network connection -
    Go to Settings --> System --> Reset Options --> Reset Wi-Fi, mobile & Bluetooth --> Reset settings
    This should sort your issue
    Aaron2017 likes this.
  3. Vamshi kandakatla , via OnePlus 7T Pro , Apr 2, 2021 :
    Sorry it's not working.
    WiFi gets disconnected frequently changes from wifi to network and network to wifi.
    dan45132 likes this.
  4. relaksua
    Donut Apr 8, 2021
    Vamshi kandakatla likes this.
  5. relaksua
    Donut Apr 8, 2021
  6. VGiri0
    Cupcake Apr 8, 2021
    VGiri0 , Apr 8, 2021 :
    Getting Annoyed with the frequent WiFi disconnection. I have close to two dozen devices connected to my home network and I don't have disconnection issue with any device other than OnePlus 7T Pro after updating to stable Oxygen 11 build.
    This issue does appear widespread. Is there any workaround? Resetting WiFi Network connection won't work in this case.
    relaksua likes this.
  7. relaksua
    Donut Apr 8, 2021
    relaksua , via OnePlus 7T Pro , Apr 8, 2021 :
    OnePlus need to look into this. This bug is eating up my data plan and what's the point to have a WiFi at home if I am using my data plan more than half the time.
  8. VGiri0
    Cupcake Apr 10, 2021
    VGiri0 , via OnePlus 7T Pro , Apr 10, 2021 :
    The most annoying thing is how I'm scared to do financial transactions on my phone because it fails when it keeps switching the network. This bug needs to be fixed ASAP.
  9. relaksua
    Donut Apr 13, 2021
    relaksua , via OnePlus 7T Pro , Apr 13, 2021 :
    I did Google about this and so far my WiFi connectivity is stable.
    I had to forget my 5GHz connection and just remain on the 2.4Ghz ...so far so good
    Vamshi kandakatla and VGiri0 like this.
  10. Sivaji Gujja
    Cupcake Apr 13, 2021
    Sivaji Gujja , via OnePlus 7 , Apr 13, 2021 :
    No it never worked. I was given 7 different set of steps to troubleshoot this issue by one plus support but none of them worked. I even did the factory reset with complete wipe but no use.
  11. J4t1np4r3kh
    OnePlus Accessory Tester Apr 13, 2021
    J4t1np4r3kh , Apr 13, 2021 :
    Many users are facing this. If simple steps to sort this are not working then report and hope it'll be fixed in the next version of the update. You can meanwhile roll back to Android 10, to avoid these bugs
  12. Vamshi kandakatla , via OnePlus 7T Pro , Apr 14, 2021 :
    Now even the calling feature hangs. Phone rings but doesn't display the call feature. Crazy development !!
    When I dial a number it follows ringing and the display turns off and only via speaker you will know that it's calling someone. Nothing on display with calling display options.
    #oneplus please look into these issues soon
  13. dan45132
    Cupcake Apr 14, 2021
    dan45132 , Apr 14, 2021 :
    I hope it works
  14. relaksua
    Donut Apr 14, 2021
    relaksua , via OnePlus 7T Pro , Apr 14, 2021 :
    Thankfully it does. My wifi no longer disconnects randomly.
    Just had to forget that 5Ghz connectivity. They better fix this annoying bug.
  15. raiankur007
    Cupcake Apr 18, 2021
    raiankur007 , Apr 18, 2021 :
    Same issue here as well with my 7T Pro McLaren edition - Wifi is connected but no internet since no apps or browser works. This has happened after updating my phone to Android 11... Come on OnePlus! You need to get better at the game of updates or else will switch to Samsung who is currently the King of Android updates!!!
  16. VGiri0
    Cupcake Apr 27, 2021
    VGiri0 , Apr 27, 2021 :
    Forgetting 5Ghz network has helped with the disconnection issue. But this bug has to be fixed.
  17. Vamshi kandakatla , via OnePlus 7T Pro , Apr 27, 2021 :
    Guys , anyone having calling issue ?
    Apps running in background like you tube, browser with sounds in background even when all recent apps cleared ?
    I get calls but I can't sed the caller name or number , my phone just rings... Same way after disconnecting or attending call the number runs background and doesn't show any display.
    #oneplus #support please fix this issue
  18. D1576766813733
    Cupcake Apr 28, 2021
  19. Paul_9.9_
    Cupcake May 5, 2021 at 2:03 PM
  20. NoFate_NoFear
    Donut May 5, 2021 at 5:50 PM
    NoFate_NoFear , via OnePlus 7T Pro Haze Blue , May 5, 2021 at 5:50 PM :
    it's just frustrating...
    Structure since years:
    - 2 AccessPoints, both 2.4 & 5GHz WiFi
    - when connected Phone shuts down Wi-Fi, connects to other Wi-Fi, shuts down again, connects again, and so on! Interval of shutdowns 10 to 50 Seconds!
    The Wi-Fi is stable, connections worked well before w/Android 10, all other Smartphones (LG, SAMSUNG) are doing good - except ONE+ running Android 11!
    Done Workaround:
    - resetting the settings > nothing changes!
    - canceled all connections except ONE > works, but THIS cannot be the solution!!! User has to decide manually WHICH Wi-Fi to use... 🤦🏼‍♂️
    In the meantime there should be an urgent solution, 'cause this is NO rare bug on some phones!!!
    plz fix!
