13
OnePlus 7t pro wifi issue post android 11 update
  1. Vamshi kandakatla , via OnePlus 7T Pro , Jun 29, 2021 :
    Let us know if it works but what's the use when u have 4G ?
    You bought the phone with 4G capacity and relying on 2g and 3g... Hahahaha #oneplus
    R1597535956276 likes this.
  2. Vamshi kandakatla , via OnePlus 7T Pro , Jun 29, 2021 :
    This is extremely sad news brother. Strange WiFi doesn't work on Google search, Even after connecting to wifi and having mobile data while able to access rest all apps. Hahahaha
    #oneplus keeps customer engaged :p
  3. Aaron2017
    General Support Expert Award 2021 Jun 29, 2021
    Aaron2017 , Jun 29, 2021 :
    It does work if you dail *#800#, that's the correct code to enter the logkit
    Caomhin and Auristic like this.
  4. Vamshi kandakatla
    Eclair Jun 29, 2021
  5. Vamshi kandakatla
    Eclair Jun 29, 2021
  6. R1597535956276 , via OnePlus 7T Pro 5G , Jun 29, 2021 :
    Yes it worked. Haven't missed anymore calls. Agree supposed no be 5G. 🤔. Hope this problem is resolved with the next update. Fingers crossed.
    Vamshi kandakatla likes this.
  7. P1623354970824
    Cupcake Jul 13, 2021
    P1623354970824 , Jul 13, 2021 :
    i have the same issues.
    all device stable, op 7t looses connection when screen off.... does not reconnect automtically, only when wifi will be selected.
    op 5t with android 10: no issues, stable.
    please update.
    ciao
    mike
  8. fidanh
    Cupcake Jul 25, 2021
    fidanh , Jul 25, 2021 :
    I am having the same issue since the very first update to Android 11. I tried resetting settings, wiping the cache, enable and disable accelerated tethering on developer mode, but none of them work.
    I have to toggle on and off with wifi to get connected to a network and the connection drops after a while. When this does not work I have to restart the phone and only then it connects to my home or work network.
    Advice or instructions highly appreciated.
  9. Q1606552318480 , via OnePlus 7T Pro 5G , Aug 2, 2021 :
    I'm going through WiFi Disconnected issues in this several days. But my other devices are connected with same router where WiFi works well but my OnePlus 7tpro McLaren not working properly. It's disconnected frequently so Need A permanent Solution.
  10. Overzee
    Junior Moderator, The Showcase Reviewer Junior Moderator Aug 2, 2021
    Overzee , Aug 2, 2021 :
    Have you tried resetting the 'WiFi, Bluetooth and data'? Keep in mind that you'll loose all the settings for WiFi, Bluetooth and data.
    Q1606552318480 likes this.
  11. Q1606552318480 , via OnePlus 7T Pro 5G , Aug 2, 2021 :
    Already 4 to 5 times I tried but I get same feedback as well.. it's not working.
  12. pablofg1978
    Head Moderator Head Moderator Aug 2, 2021
    pablofg1978 , Aug 2, 2021 :
    Thread merged
  13. dreamkiller1295
    Cupcake Aug 14, 2021
    dreamkiller1295 , Aug 14, 2021 :
    WiFi-related Problems since past few months:
    1st problem: Bluetooth switches on whenever I switch on WIFI
    2nd problem: The phone disconnects randomly from all networking systems, i.e.: WiFi, mobile network and phone signal on both SIM cards, and WILL reconnects all networks after 5-10 seconds.
    Device: Oneplus 7T Pro
    Android Version: 11
    Oxygen OS Build number: 11.0.2.1.HD01AA
    0253
    KKRWORLD likes this.
  14. IH8Speedbumps
    Gingerbread Aug 17, 2021
  15. KKRWORLD
    Cupcake Oct 14, 2021
    KKRWORLD , Oct 14, 2021 :
    Seems restarting the phone is the only option. I have to keep doing that at least 3-4 times a day. 🙄
  16. sufi09
    Honeycomb Dec 18, 2021
  17. IH8Speedbumps
    Gingerbread Dec 21, 2021
  18. DR_WELL
    Cupcake Jan 16, 2022 at 7:19 PM
    DR_WELL , Jan 16, 2022 at 7:19 PM :
    Who has a problem with constantly falling off WiFi in the router settings, change the encryption from WPA-psk + WPA2-psk to WPA2-psk + WPA3-psk.
