84
OnePlus 7T Specs Explained: Snapdragon 855+ Processor
  1. pooja5511
    Cupcake Oct 10, 2019
    pooja5511 , Oct 10, 2019 :
    Is the phone bent from the top and bottom , it's feature or defect in my phone
  2. stansuys
    Gingerbread Oct 10, 2019
  3. DevB91
    Cupcake Oct 11, 2019
    DevB91 , via OnePlus 7T , Oct 11, 2019 :
    JelleZon
    well
    I think the faster / higher clock speed and more power will lead to worse battery life? can that also be the case?
    because the sd855+ is not advertised as "more efficient" or " X% less power consumption" etc.
    worried about that.​
    Not necessarily. So upon checking up available information we know that the 855+ uses Vulkan graphics drivers instead of Open GL. This causes the GPU on the 855+ to be more power efficient. So the worry about the extra battery drain due to the GPU over clocking actually gets nullified.
    As for the CPU, if there's a 4% bump in CPU performance and it equates to 4% extra battery drain we would also have to consider that tasks that were earlier taking 4% longer time will now take 4% lesser time to complete. This although would lead to the worry that a consistent sustained higher clock frequency may lead to an additional drain.
    That additional drain is additionally subject to usage patterns. A person not pushing the CPU to the limit where it has to sustain higher clock frequencies may not face this additional drain. This is because in his use case he isn't pushing and sustaining the CPU at higher clock frequencies. So in a nutshell, it kind of depends.
    JelleZon likes this.
  4. JelleZon
    Lollipop Oct 11, 2019
    JelleZon , via OnePlus 6T Mirror Black , Oct 11, 2019 :
    how does the vibration motor feels?
    in comparison with older devices like 6/T for example
  5. P1570741503411
    P1570741503411 , Oct 11, 2019 :
    I noticed my Bluetooth headphones not showing up for pairing with my new OnePlus7T. Does anyone facing similar issue?
  6. T1565253301586
  7. paparobo
    Eclair Oct 12, 2019
    paparobo , via OnePlus 7 , Oct 12, 2019 :
    who the **** asked u attention seeking loser
  8. W1570902691310
    Cupcake Oct 12, 2019
    W1570902691310 , via OnePlus 7T , Oct 12, 2019 :
    i cannot connect sony bluetooth headset with my one plus 7t device.. it's not able to search the headset only.. it was easily getting connected with my op3t device
  9. Messagepads
    Gingerbread Oct 13, 2019
    Messagepads , Oct 13, 2019 :
    Ok, I'm not a compulsive gamer so this "plus" processor does not bring any noticeable improve right?
    Be cautious of entering into the usual race of who has the biggest one just for fun and keep inovating as you did from day one.
    Cheers OnePlus !
  10. P1570302956126
    Cupcake Oct 13, 2019
    vikramchinu likes this.
  11. Nilesh bajaj26
    Froyo Oct 14, 2019
    G1565097698909 likes this.
  12. paparobo
    Eclair Oct 14, 2019
    paparobo , via OnePlus 7 , Oct 14, 2019 :
    drdevangjoshi
    When OnePlus realise that they have launched a better device than their flagship at a lower price !!
    OnePlus 7 pro users need not worry about 855+ if you are not gaming.​
    even that flagship wont be a flaggship in 3_4 months. shitty business mate [e]1f602[/e]
  13. M1564933342715
    Cupcake Oct 17, 2019
    M1564933342715 , Oct 17, 2019 :
    I can only get 5 hrs playing one certain game before recharge needed. at this point phone sonhot can't hold .warrantees phone so this is the second. don't know if 115 deg is normal but after 98 things get glitchy. not just games but movies also( downloaded bnot stream) if u getting better I'd like to know how as I'm using fhd and 60 hz.
    DevB91 likes this.
  14. D1569917789078
    Cupcake Oct 19, 2019
  15. vikramchinu
    Donut Oct 25, 2019
    vikramchinu , Oct 25, 2019 :
    bring back a complete ui dark mode tplease... the grey mode..making the like display Has some problem.. as it is tinting at top..... please make this change..or give option in customization
  16. Nilesh bajaj26 , via OnePlus 7T Glacier Blue , Oct 25, 2019 :
    green tint is display problem check in forums
  17. vikramchinu
    Donut Oct 25, 2019
    I checked that .. but... it should come in the mode.. when the phone is locked and we pick..where clock is displayed . there it pitch dark...... of display problem.. then it should give there also problem...... .... in the posts..the before and after pics are not that great to clearly distinguish......
    onepl is not acknowledging openly that statement of display problem.... all u see is they are replacing in service centers....
    I need to check in my old 5t if that is same........
    if we contact support that simply s copy paste the info once shared in community....
    Nilesh bajaj26 likes this.
  18. HarmfulGrub8
    Cupcake Nov 16, 2019 at 12:02 PM
