37
OnePlus 7T Specs Explained: Warp Charge 30T
  1. Anterone
    Cupcake Oct 13, 2019
    #41
  2. Anterone
    Anterone , Oct 13, 2019 :
    ok, thanks!
    #42
    MosheG1 likes this.
  3. MosheG1
    The Lab - OnePlus 8 Pro Reviewer Oct 13, 2019
    #43
  4. KeBlam
    US Brand Ambassador Oct 13, 2019
    #44
  5. Y1541095207012
    Y1541095207012 , via OnePlus 6 , Oct 13, 2019 :
    Preferably made by Xiaomi. And the powerbank should warp charge as well. Is the warp charge brick backwards compatible with the Oneplus 6?
    #45
  6. F_Murali_Reddy_nMOI
    F_Murali_Reddy_nMOI , Oct 13, 2019 :
    I am bought 7T today I moved from S8+. n my first impressions are battery drain, heavy and heating issue.
    screen not great compared to S8+.
    call of duty game cropped and finally game crashed.
    pubg was running good . camera ok.
    overall not worth 40k.
    #46
  7. santosh.pandey
    #47
  8. Deependra bahadur
    Deependra bahadur , Oct 13, 2019 :
    same here...
    #48
  9. Afnaan
    Donut Oct 14, 2019
    Afnaan , via OnePlus 7T , Oct 14, 2019 :
    battery is draining too fast
    I'm a normal user and I am charging my 7t twice a day
    not satisfied with battery back-up
    can the send any update to increase the battery life.
    some time touch also not working properly.
    #49
    shubham29jan likes this.
  10. shubham29jan
    Cupcake Oct 14, 2019
    shubham29jan , Oct 14, 2019 :
    T1570467437403
    not satisfied with battery backup[e]1f62d[/e]
    can the send any update to increase the battery life???​
    same , right now my battery is at 94% n it's showing it will last till 3:15, means 6 hours only .. that's not good at all
    but thanks to fast charging
    #50
    rahulopg likes this.
  11. rahulopg
    Ice Cream Sandwich Oct 14, 2019
    rahulopg , via OnePlus 7T , Oct 14, 2019 :
    hmm though I am getting a SoT of 5.5 hrs to 6 hrs 15 mins but from various comments here it seems that a battery optimization update is required for sure.
    hope OnePlus is working on it
    #51
  12. Vijay7T
    Vijay7T , Oct 14, 2019 :
    Charging speed is great!, but battery life is very average. You can see battery percentage going down fast while using it.
    #52
  13. PrinceKamal
    Froyo Oct 14, 2019
    PrinceKamal , via OnePlus 7 Pro , Oct 14, 2019 :
    then you should have gone for pro varient either 7 pro or 7t pro.. only 7 k difference was there.. and i suggest every samsung s series user to do that.. it's obyous you might be dissatisfied with 7t screen looks.. but if taking about performance.. it's flawless in case of 7t too.. way better then s8 in every aspect.. but if that's design that bothers you then you should have considered 7 pro.. its way more immersive then 7t
    #53
  14. rahulopg
    bro I m palying COD from 4th now but I have never seen any free.drops and it has never crashed and runs smoothly.
    S8+ is quad HD but this is not but this has 90hz refresh rate which make it better in my opinion.
    #54
  15. rahulopg
    true even I can see battery going as I'm using... battery drains needs to be stopped.
    Guys please register this battery drain issue in.the community feedback app.
    #55
    Vijay7T likes this.
  16. G_Nandagopal_BR_XNAA
    G_Nandagopal_BR_XNAA , Oct 14, 2019 :
    Very useful article on Wrap charging, but I am using 7T from 2weeks , when I initially unboxed the phone battery pack up good after a day received update, Post software update battery is draining out very fast. Never expect this from a New device
    I feel my 2years old One Plus 5 's battery lasts longer compared to 7T ,very disappointing.
    #56
  17. PrinceKamal
    Froyo Oct 14, 2019
    that's a demerits.. hope they ll fix it by software updates.. i think tech is not so advanced right now too.. so that charging speed can be improved without compromising anything..
    #57
  18. Akhand_Pratap_Singh
    Akhand_Pratap_Singh , Oct 14, 2019 :
    i think, you probably use only social media or browser. Have you played high graphic games?
    #58
  19. shubham29jan
    haha true while playing pubg it lasts only 4 hours [e]1f602[/e][e]1f602[/e]
    #59
  20. ashishkum94
    Froyo Oct 15, 2019
    ashishkum94 , Oct 15, 2019 :
    i 100% agree. im facing the same issue regarding this aswell. and there are many others too facing the same 7T drain issue. I hope this comes under oneplus devs notice and they fix it soon.
    #60
    Dhruv Kashyap likes this.
