13
Other Oneplus 7T Using 27GB Of System Storage
  1. E1510854199402
    Froyo Oct 13, 2019
    E1510854199402 , Oct 13, 2019 :
    Why does the oneplus 7t consume so much system storage, 27gb.
    my oneplus 5t fully up to date only uses 5.8gb of system storage.
    that’s a huge difference ?
    so I have less free space that my previous 5t which has the same total capacity (128gb)
  2. E1510854199402
    Froyo Oct 14, 2019
    E1510854199402 , Oct 14, 2019 :
    Can someone confirm on their new 7t they have a similar used system storage please.
    seems excessive to me.
  3. Sumit.Ac3
    Donut Oct 14, 2019
    Sumit.Ac3 , Oct 14, 2019 :
    E1510854199402
    seems excessive to me.​
    yes i can confirm this but i dont mind as i bought one with 256 gb internal
    Nazzy7, Rohan2105 and Kiran Chinta like this.
  4. bond007
    Eclair Oct 14, 2019
    ARAGONDA BALAJI likes this.
  5. guanyu210379
    Jelly Bean Oct 14, 2019
    guanyu210379 , Oct 14, 2019 :
    Note!
    7T (non-Pro) 8/256GB is not available for us in Europe.
    Having 28Gigs only for the defalt ROM is NOT good!
    manishrchandran and Sumit.Ac3 like this.
  6. TheJoker2795
    Gingerbread Oct 14, 2019
  7. Intruder71
    Lollipop Oct 14, 2019
  8. Horsault
    Nougat Moderator Oct 14, 2019
    Horsault , Oct 14, 2019 :
    I can remember the days when Windows installation files fit in about 10 1.44MB disquettes, and MS-DOS + Windows ran perfectly on a 5MB HDD, leaving plenty of space for other programs and data.
    Now, a 32GB HDD is barely enough.
    This is called evolution.
    But I'm pretty sure there are a lot of other files than pure system on your storage, like temporary files, cache, etc.
    OALEXANDER, Muzz1, Bouncer71 and 2 others like this.
  9. E1510854199402
    Froyo Oct 14, 2019
    ok thanks for confirming guys, that's such a shame really, if they sold a 256gb version i would have got one, but for us we only have one storage option.
    Stupid :-(
    vikramchinu likes this.
  10. Intruder71
    Intruder71 , Oct 14, 2019 :
    Oh the days loading MS-DOS from 3 floppy disks, then windows for workgroups 3.1 from was it 9? Memory isn't what it was as I'm old lol
    Bouncer71 and WoTh997 like this.
  11. guanyu210379
    I want the turbo button back! ^o^
    The cool 16Mhz e.g. by default will got pumped up to 21Mhz only with a press of a button
  12. B_Wrath
    Nougat Oct 14, 2019
    B_Wrath , Oct 14, 2019 :
    Just out of curiosity. This 27GB of system data was there when the phone was just out of box or after you set it up?
  13. Intruder71
    Tbh I was more into amiga's far superior to any 286 or 386 which was the norm at the time... Not forgetting those old SCSI drives the size of two shoes boxes on top of each other...
    Bouncer71 likes this.
  14. E1510854199402
    Froyo Oct 14, 2019
    After i set it up, i did not check it at first, i done the small update to 10.0.3 and was getting all the updates and then they just stopped and was stuck at installing and download pending, i could not resolve by clearing the cache and data etc. so i carried out a factory reset and that cured the update issue. then set it all up and noticed it.
  15. Scherpenseel
    KitKat Oct 14, 2019
    Scherpenseel , Oct 14, 2019 :
    Could be that the installation files are still on the phone?
  16. Horsault
    Even MS-DOS 5.5 (and maybe 6) fitted on only one disquette.
    MS-DOS 3.3 required one double sided 5.25" 720kb disquette, and there was some space left.
  17. E1510854199402
    Froyo Oct 14, 2019
    Could be, would wiping the cache during restart help ?
    The volume down and power button trick.
  18. B_Wrath
    Nougat Oct 14, 2019
    That does absolutely nothing on A/B partition devices.
    Anyways, you can try flashing the full rom once again. It will shift the active slot. Just give it a try.
  19. Intruder71
    6.2 was more like 3.5mb to 4mb
  20. E1510854199402
    Froyo Oct 14, 2019
    ok thanks, yes when i get a minute i might give it a go, although others on here have also confirmed the system space used is the same.
    S1588034462610 likes this.
