14
Other Oneplus 7T Using 27GB Of System Storage
  1. makerlimo95
    Cupcake Oct 24, 2020
    makerlimo95 , Oct 24, 2020 :
    Just got my new 7T a few hours ago. I love everything so far except for the crazy high 26 GB system storage usage. My old OnePlus 5 running OOS 9.0.8 only used 7 GB for system storage. I honestly feel robbed of nearly 20 GB storage capacity. Two questions:
    https://omegle.onl/
    • Did stock Android 10 also quadruple system storage or is it just OnePlus?
    • Is there any way to get some of it back? I would root my phone just for this if it helped.
    Before someone suggests it: yes, I did a factory reset without bringing over my old data, just to be sure it wasn't me.
  2. Edithstark
    Froyo Oct 25, 2020
    Edithstark , via OnePlus 7T , Oct 25, 2020 :
    It is the same after 1 year.
    That is what happens when you stop someone from raising their voice against others
    Neelavar Sumanth likes this.
  3. NeelavarSumanth
    Gingerbread Oct 25, 2020
    NeelavarSumanth , via OnePlus 7T Pro , Oct 25, 2020 :
    Only the 7 (t) devices have the android system take up 26 to 30GB of Storage . I've checked both 7 & 7pro myself , they have closer to 14-16 GB system storage. I don't know about the Newer 8 series devices .
    Mine is a 7T pro , been using it for an year . Shifted to & back from Open Beta . Android system takes 30 GB right now 😂.
    Its a joke at this point
  4. oommert
    Cupcake Oct 27, 2020
  5. Depth_47
    Donut Oct 27, 2020
  6. GaganCK
    Gingerbread Oct 27, 2020
  7. Christian145
  8. Deactivated User
    Nov 9, 2020
  9. GENISYS07
    Cupcake Dec 14, 2020
    GENISYS07 , via OnePlus 8 Pro , Dec 14, 2020 :
    I need the same answer for my Oneplus 8 Pro because it's showing me that my system storage is 32GB. I mean what the hell is this.
    Why the hell it's so large??
  10. BeingIncog
    Nougat Dec 14, 2020
    BeingIncog , Dec 14, 2020 :
    read few posts above, already answered ...
    the_o2 likes this.
  11. yamandabas
    Eclair Dec 14, 2020
  12. the_o2
    OnePlus 9 Series Expert Community Expert Dec 15, 2020
    the_o2 , Dec 15, 2020 :
    Because A/B partitioned devices need that much update to provide seamless updates, and don't compare it with OP5 series devices they don't have the proper A/B partition.
    You can search on Google for this you will get lots of better article
    Then delete the useless file, I don't think your storage is full because of system is taking 50GB...
    Upto 35 it would take max.
    And please don't bum up old threads, search once before posting.
  13. Bhaveee
    Honeycomb Dec 15, 2020
    Bhaveee , via OnePlus 7T , Dec 15, 2020 :
    Every android skin with tweaks and optimizations will take up space for the extra amout of code for those features, whether its OOS or any other skin. Samsung one ui takes more than 32 gb of space (this was back in s10+ time. It might be way more than this now)
  14. Karx100
    Gingerbread Dec 15, 2020
    Karx100 , via OnePlus 7T , Dec 15, 2020 :
    That's why i bought 256gb variant instead of 128gb. Also you can use cloud storage of oneplus and google. That will save your space.
  15. OALEXANDER
    Assistant Head Moderator Assistant Head Moderator Dec 15, 2020
    OALEXANDER , Dec 15, 2020 :
    Thread merged
  16. sufi09
    Gingerbread Dec 16, 2020
