OnePlus 7T warp charger not working
  1. Sumitkolhatkar
    Cupcake Jul 4, 2020
    Sumitkolhatkar , Jul 4, 2020 :
    I have purchased OnePlus 7T on 04.12.2019. 30T warp charger not working (within 6 months) for my OnePlus 7T.
    This is so frustrating that even after spending lot of money we are not getting standard quality product from OnePlus.
    I have raised issue ID: 200627-004360 however no response from OnePlus customer care after 7 days. My product is within warranty period so requesting you to take immediate action. Screenshot (for warranty) is attached herewith for your reference.
  2. Dr Anisul Islam
    Donut Jul 4, 2020
    Dr Anisul Islam , Jul 4, 2020 :
    try to clean the charging pins. same issue happened on my friend's 6T after cleaning the dusts it's working fine.
  3. Sumitkolhatkar
    Cupcake Jul 4, 2020
    okay...I will check this. Thanks for sharing information.
    Dr Anisul Islam likes this.
  4. Dr Anisul Islam
    Donut Jul 4, 2020
    you're welcome Sir
  5. Sumitkolhatkar
    Cupcake Jul 4, 2020
    Hard luck... charger is not working even after cleaning pins. I can be able to charge my phone using USB data cable so there must be fault in 30T warp charger.
  6. Dr Anisul Islam
    Donut Jul 5, 2020
  7. humzagr8
    Cupcake Jul 19, 2020
    humzagr8 , Jul 19, 2020 :
    also have the same issue can you guide me whether it's charging big issue or a cable issue I am facing the problem suddenly
  8. Sumitkolhatkar
    Sumitkolhatkar , Jul 19, 2020 :
    Charger issue for me...not working (made in China). Cable is working fine & I am charging my device using USB cable.
