32
Oneplus 7T
  1. W1597338972522
    Donut May 10, 2021
    W1597338972522 , via OnePlus 7T , May 10, 2021 :
    Bro I am facing fingerprint scanner issues....it disables itself and it will not scan....only after restarting it gets back to normal state ..
  2. #22
    dipesh211 and Sushantbhoje like this.
  3. O1584780010028
    Cupcake May 11, 2021
    O1584780010028 , via OnePlus 7T , May 11, 2021 :
    Team,
    Hi Team,
    I am experiencing an issue in my gallery where it takes more than 30 minutes to show the exact count of the data. It takes more than half n hour to get updated with all photos and videos. It gets stuck in between and takes so long to update all the data.
    Please note that this is happening only after the latest update to OS 11 version. Before this version, this never happened and gallery folder used to get updated in less than 2 minutes.
    Please check this on priority please and raise a bug or a defect accordingly.
    Thanks
    Sushantbhoje likes this.
  4. Gaurav Sohni
    Gaurav Sohni , via OnePlus 7T , May 11, 2021 :
    1) Memory processing speed slow
    2) With lagged response 90Hz display scrolling isn't usefull at all
    3) Google Assistant wake-up anytime, even in the pocket also
    4) even Gallery is also slow in loading pictures
    5) Camera tweaked down
    dipesh211, Sushantbhoje and Vikas4u like this.
  5. iemafzal
    Eclair May 11, 2021
    iemafzal , via OnePlus 7T , May 11, 2021 :
    A request
    Kindly build fps meter in games section,
    And please optimise oxygen os 11 .
    It lags when i restart my oneplus 7T, it also lags while opening and playing pubg,
    Kindly consider this comment and work for it.
  6. Hasnain159
    Hasnain159 , via OnePlus 7T , May 11, 2021 :
    1 Auto brightness not working properly...
    2 Battery daring just 4 Hours
    3 Touch sound slow
    4 Gaming heating issue
    5 90Hz Refresh rate not working properly
    6 Screen on time just 4 Hours
    7 Warp charging speed slow it is take 1hour 45 minutes.
    8 Gallery app loading so many take time
    9 Gallery photo are missing
    10 Sometimes camera app is lagy and it is not responding
    11 11.0.0.2 update camera quality pictures so bad
    Please solve all bug immediately a another I am dwongrade android 10 stable..
  7. Kawaipotato
    Kawaipotato , via OnePlus 7T , May 11, 2021 :
    Im experiencing a lag when i navigate the OS. Cant tell if its the refresh rate changing a lot or if the OS is just laggy. Only appeared after the Android 11 update :/
  8. L1574226553285
    Cupcake May 12, 2021
  9. Teja_Ps
    Eclair May 12, 2021
  10. sarthak178
    Donut May 12, 2021
    sarthak178 , via OnePlus 7T , May 12, 2021 :
    Similar performance issue faced after OS11 update.
    Phone overheating and crashing games very frequently.
    The main reason for getting this phone at the time was for gaming.
    I play COD frequently and in every session the game crashes after 10-15min of game play and overheat.
    Wish I hadn't updated
  11. mostlylove
    Eclair May 13, 2021
  12. A1606922730418
    Cupcake May 13, 2021
    A1606922730418 , via OnePlus 7T , May 13, 2021 :
    Battery draining is the real problem than heating. Man please fix this oneplus . Or guys does anybody know hoe to downgrade it?
    I wanna stick yo the previous one
  13. kratverma
    Donut May 13, 2021
    kratverma , via OnePlus 7T , May 13, 2021 :
    Since the last update, i don't understand why the developers are so lazy or what, or they are paid to do such a job. The phone is so lagy and buggy right now. It was way better earlier.
    This new update has tones of problems, the most annoying is screen stuttering like hell, once you put your phone in 90hz it will randomly starts slowing down reducing refresh rate to the lowest. There are countless problems are my fellow friends posted already and this is serious if you're not good at doing something putting your 100% effort don't do that naa!! The company should provide an option to rollback to the previous one.(I know its possible but 🙂)
    Dear one plus stop doing with the OEMS, if its a paid job to make the phone slower. Then my dear good friends you are doing your best job 😊🙏🏻 and will see the results within couple of days. Not a single has survived this hustle after making there consumers or putting them to a situation like it is now for 7 series owners.
    Company work on a feedback system and i guess you guys are getting enough feedback nowdays. Information is considered as the backbone of any company and how you manipulate with the right group of person decides the direction of the company in going up or down. And it is going ⬇️.
    Thankyou
  14. kratverma
    Donut May 13, 2021
    Thankyou
  15. OmarbAhmed
    Donut May 13, 2021
    OmarbAhmed , via OnePlus 7T , May 13, 2021 :
    You can reset Wifi, Mobile Data and Bluetooth settings
    I called the OnePlus helpline and they suggested the same.
    It worked for me !
    sunnyTheBong likes this.
  16. Iampbhagia
    Iampbhagia , via OnePlus 7T , May 13, 2021 :
    Battery charging issue, battery drain, wifi disconnecting no wonder why, lag while performing daily tasks, notification shade unresponsiveness, what is it Oxygen OS 11 or Shit OS 11? No wonder you guys are degrading your quality day by day. Ironically, they write the first line in update change log as "improve the overall system stability".
  17. Wadu69Hek
    Sushantbhoje and Z1591330853714 like this.
  18. Z1591330853714
    Z1591330853714 , via OnePlus 7T , May 13, 2021 :
    I was really impressed when i first started using OnePlus devices. Buf after this oxygen os 11 update every expectation is shattered. There is a lot of big and minute issues we all 7 series users are facing and yet there is no word form the company about the promises of these fixes. We are kindly requesting for proper fix for all these issues.
    #38
  19. Sanchit1701
    Donut May 14, 2021
    Sanchit1701 , via OnePlus 7T , May 14, 2021 :
    Oneplus has joined the club of Oppo, Vivo now. It's no more a flagship killer. It's just like any other phone you can find in market. Software updates are pathetic. Specially for older models. This will be my last Oneplus phone for sure.
    #39
  20. _Andrei_Vavrita_
    Donut May 14, 2021
    #40
