27
Oneplus 7T
  1. sunnyTheBong
    Donut May 14, 2021
    #41
    Sushantbhoje likes this.
  2. sunnyTheBong
    Donut May 14, 2021
    #42
  3. Sushantbhoje
    Cupcake May 15, 2021
    Sushantbhoje , via OnePlus 7T , May 15, 2021 :
    Gallery opening issue.....apps hangout....bugs in UI face,
    Heating issue, brightness issue, sound low in 11 than android 10 , battery drain issue...plz solve this in asap
    #43
  4. Sushantbhoje
    U can watch techibee YouTube channel
    #44
    GGanesh likes this.
  5. GGanesh
    Donut May 15, 2021
    GGanesh , via OnePlus 7T , May 15, 2021 :
    No use after providing the feedback also.
    Team will aks for the logs, will share the logs.
    After that there will be o updates from OnePlus team
    #45
  6. Shailender Sharma
    Marshmallow May 15, 2021
    #46
  7. GGanesh
    Donut May 15, 2021
    I would say it's just a post to calm down the people , if you really want to know the exact realities, I can give you the examples.
    I have logged the tickets long long back, untill I submit the logs I was getting the replies. After I submit the logs no replies from the respective team. I kept quite after asking multiple times for the response. And same getting repeated for latest feedback also.
    Generic Replies:
    When ever we submit a feedback we will get a automatic reply saying,
    1. Steps to share the logs
    2. And where to keep the logs
    3. Attach the screen shot for reference
    This we will get irrespective of the issue reported, for example I have reported issue related to charging and heating issue.
    For heating issues they are asking me to give the screen shot, how is it possible to give the screen shot for heating issue.
    Same question I have asked the respective person 2 weeks back( For heating issue alone), still no response.
    Even there is situations where they have assigned the ticket to different region team and they took more then a 1 month to respond, and after 1 month they gave response saying, mistakenly the ticket assigned to different region. we are re assigning the ticket to correct region again. After that also I didn't get proper response that is a different point again.
    There are many incidents we can keep on adding it to the list.
    #47
  8. E1577183284498
    #48
  9. Soni_Kunal_rudv
    Donut May 15, 2021
    #49
  10. Digantb
    Digantb , May 15, 2021 :
    Thank god I did not update!
    But OnePlus official said they would be rolling a new update bt the end this month.
    #50
  11. Sanchit1701
    Donut May 17, 2021
    #51
  12. Popon
    Cupcake May 19, 2021
    Popon , via OnePlus 7T , May 19, 2021 :
    How to this? Wipe all the data?
    #52
  13. Sanchit1701
    Donut May 19, 2021
    Sanchit1701 , via OnePlus 7T , May 19, 2021 :
    No, download the firmware from
    https://www.oneplus.in/support/softwareupgrade/details?code=PM1574161738631
    Rename the file if it has .jar in the end. Keep the file name till .zip only.
    Place the file in root directory. Means simple place the file directly in internal storage directory. Not in any folder.
    Then goto Settings -> System -> System Updates -> Local Upgrades
    Select the file from which you have to reinstall the firmware
    Wait for completion
    This does not delete your existing data
    #53
    JonathanJo likes this.
  14. VinitBelam
    VinitBelam , May 19, 2021 :
    Is there any way to prevent the update notification to the latest Android from appearing. I'm sick of it, it pops up every couple of days and can't disable it... I will upgrade in due time when I choose so not because Android insists on it.Mobdro
    #54
  15. The Kaifu
    Eclair May 21, 2021
    The Kaifu , via OnePlus 7T , May 21, 2021 :
    It very much is the only solution. I myself downgraded from 11.0.0.2 to 10.3.8 yesterday and now my phone feels like new. My advice, skip 11.0.0.2 and future updates until OnePlus really fixes the issues properly
    #55
  16. Sanchit1701
    Donut May 21, 2021
    Sanchit1701 , via OnePlus 7T , May 21, 2021 :
    What are the steps to downgrade to OOS 10?
    #56
  17. Sanchit1701
    Donut May 21, 2021
    I literally feel Oneplus ruined the Oneplus 7T camera with Android 11. Such an amazing camera module which was working pretty decent till Android 10 is now a trash.
    This is what Oneplus do with older phones!
    #57
  18. Mrunal Semitha
    Eclair May 23, 2021
    Mrunal Semitha , via OnePlus 7T , May 23, 2021 :
    Finally downgraded from Android 11 stable update to Android 10 stable update with the help of OnePlus technical support, there's a lot of delay in support as all users are downgrading OS, there's one thing to note, the Android 10 OnePlus technical support guys downgrades is Android 10 with 2019 security patch, luckily I had downloaded the January Android 10 OS with 2021 Jan security patch from OnePlus website before it was replaced with Android 11, I locally updated later,
    Hope OnePlus fixes all the issues soon, else we'll no longer be OnePlus fans!.
    #58
    V1574704073048 likes this.
  19. rkmuthalagan
    Cupcake May 24, 2021
    #59
  20. V1574704073048
    V1574704073048 , via OnePlus 7T , May 24, 2021 :
    Can you please help in letting me know steps to downgrade..I am fed up with my phone..all apps crashing..not able to do calls..etc
    #60
