32
Oneplus 7T
  1. S1624371795151
    Cupcake Jun 22, 2021
    S1624371795151 , via OnePlus 7T , Jun 22, 2021 :
    Hello Oneplus,
    I'm a fan of Oneplus since the Oneplus 1.
    I've had the 1, 2, 5 and currently still the 7T.
    The issues after the android-update are decreasing my fun-experience.
    When will these problems with the 7T be fixed?
    #81
  2. Helder_DAlmeida
    Marshmallow Jun 22, 2021
    Helder_DAlmeida , via OnePlus 7T , Jun 22, 2021 :
    No one knows but hope it will be soon
    #82
    Shailender Sharma likes this.
  3. abhisek9467
    Cupcake Jun 24, 2021
    #83
  4. Shailender Sharma
    Nougat Jun 25, 2021
    Shailender Sharma , Jun 25, 2021 :
    Steps To Fix DRM Issue
    Open Settings in your device.
    Scroll down and select Apps.
    Scroll down and select Hotstar/Amazon Prime etc.
    Then clear Cache.
    Restart your device.
    if still, the error persists, you can try checking your current time, ensure that it is IST AM/PM.
    https://www.techblunt.com/fix-drm-issue-in-hotstar/
    #84
  5. Pasza122
    Cupcake Jun 26, 2021
    Pasza122 , via OnePlus 7T , Jun 26, 2021 :
    Still got refresh rate issue. With no reason and no app on background refresh rate is dropping to 50 Hz and fingerprint scanner does not work. I have to manualny change it to 60 Hz and then back to 90 Hz to fix issue and its very irritating. Make this fix, because right now its make 7T my last OP phone ever...
    #85
  6. AlwaysOneplus
    Gingerbread Jun 27, 2021
    #86
  7. Z1623814543045
    Cupcake Jun 29, 2021
    #87
  8. #88
  9. T1576596171042
    Cupcake Jul 24, 2021
    T1576596171042 , via OnePlus 7T , Jul 24, 2021 :
    Same issue bro... Wifi keep on disconnecting for no reason. I will never buy one plus phones again
    #89
  10. sunnyTheBong
    Eclair Jul 25, 2021
    sunnyTheBong , via OnePlus 7T , Jul 25, 2021 :
    U better update the system with latest version. It will permanently fix this issue. 👍👍
    #90
  11. Aishu@13
    Cupcake Aug 4, 2021 at 11:32 AM
    #91
