6
OnePlus 8/8 Pro - O2 5G
  1. thomasb4544
    Donut May 15, 2020
    thomasb4544 , via OnePlus 8 Pro , May 15, 2020 :
    I did, I tried a few of the ones mentioning "UK" until it worked.
    Cerbervs likes this.
  2. starsky135
    Eclair May 18, 2020
    thomasb4544 likes this.
  3. ChrisKeegan
    Donut May 19, 2020
    ChrisKeegan , May 19, 2020 :
    I hope OnePlus pull there finger out and introduce 5G on O2 soon. Ridiculous that we are expected to mod things ourselves to get these kind of speeds out of a device that is meant to be sold as Flagship 5G.
  4. JulianLa
    Froyo Jun 7, 2020
    JulianLa , Jun 7, 2020 :
    Thanks all.
    I'm guessing the O2 fix will only come in an update for phones with EU software version (I just changed mine from Global to EU)
  5. jhoon_09
    Gingerbread Jun 12, 2020
    jhoon_09 , Jun 12, 2020 :
    Here is the solution guys :
    If your OnePlus 8 pro , OnePlus 8 or Oneplus 7T pro 5G is not connecting to 5G in 5G covered area .
    # Use single 5G SIM card in number 1 slot.
    Follow the steps here :
    Requirements:
    1- install EngineerMode apk manually on your phone:http://www.mediafire.com/file/i72tnya1aawo09v/Engineeringmode_V1.01.0.apk/file
    2- On you computer you need to have OnePlus driver installed:
    http://www.mediafire.com/file/zkua1ob0dzaor09/OnePlus_USB_Driver_Setup.exe/file
    3- QPST-application. Please find application from internet:
    http://www.mediafire.com/file/ocpqez9whauy5w6/QPST_2.7.474.zip/file
    4- The two XML files with enabled 5G network:http://www.mediafire.com/file/go0qava73eiz0m6/Carrier_Policy.zip/file
    5- USB-cable between your computer and phone.
    When you finish and ready:
    1- On phone you have to dial to *#801# and enable Rndis, diag switch. Don’t enable Serial-interface if you have installed apk manually.
    2- Connect your phone to your computer via USB.
    3- Open then QPST-application.
    4- On the menu Open Start Clients then QPST EFS Explorerand wait until you see the files.
    5- Then go to policyman.
    6- In the policyman - right list, you will see two files : carrier_policy.xml and carrier_policy.xml_Subscription01. Copy them to your computer as a backup if you need them in the feature.
    7- Now delete the two files (carrier_policy.xml and carrier_policy.xml_Subscription01) files from the policyman - right list.
    8- Now go to the tow XML files you already download earlier – 5G enabled network. Copy them to the policymandirectory , drop and drag one each time.
    9- Reboot your phone , your 5G is enabled now.
    On OnePlus 8 and 8 Pro you may have to enable 5G NR via *#*#4636#*#* then Phone Information -> Set preferred network type. Choose :
    NR/LTE/TDSCDMA/CDMA/EvDo/GSM/WCDMA
    Or
    NR/LTE/TDSCDMA/GSM/WCDMA
    Enjoy the 5G speed .
    Very Big Thanks to:
    1- Mr. Minh Truong:
    https://mt-tech.fi/en/modify-oneplus-7-pro-5g-8-and-8-pro-nr-lte-a-band-combos/
    2- Mr. Abdullah Alshehri :
    https://twitter.com/AdAlShehri737
    3- Mr. Mussab Alghamdi :
    https://twitter.com/MussabAlghamdi
  6. fubar3803
    Froyo Jun 12, 2020
    fubar3803 , via OnePlus 8 , Jun 12, 2020 :
    What update version nr is that?
  7. feroze
    Froyo Jun 12, 2020
  8. feroze
    Froyo Jun 12, 2020
    feroze , via OnePlus 8 , Jun 12, 2020 :
    Found some 5G on Three when I was out locally on Wednesday. It's been switched on in the area since the start of the month. Speeds, however, were awful
  9. jhoon_09
  10. G_*Nick*_ikuO
    Cupcake Jun 16, 2020
  11. Bloomeroid
    Cupcake Jul 17, 2020
    Bloomeroid , Jul 17, 2020 :
    Very disappointed that the OnePlus 8pro only works for Three on 5g in the UK. Three customer retention team told me they have no plans to roll out 5g to Northern Ireland leaving me with O2 as my only option for 5g in Belfast. Now I find that O2 and oneplus have fallen out and won't enable 5g support from either end. It's very disappointing. OnePlus used to be amazing now, they are holding back on their customers, even the ones who pay for they top tier devices.
  12. cocodude
    Eclair Jul 20, 2020
    cocodude , Jul 20, 2020 :
    I can confirm the process above (changing the carrier profile xml and then installing a 5G switcher app and using it on every reboot) works just fine with me in London. See speedtest for London, N1:
    Does anybody know if there is a way to do the .xml change via Linux?
    Also, has anybody had any luck complaining to OnePlus about this? It's clearly their fault here. I would certainly argue ot contravenes the Sales of Goods act in the UK as it's most definitely not fit for purpose as they're purposefully blocking 5G.
  13. cocodude
    Eclair Jul 20, 2020
  14. thepixel
    Eclair Jul 29, 2020
  15. scarty16
    Donut Jul 30, 2020
  16. dragon2611
    Cupcake Aug 2, 2020
    dragon2611 , Aug 2, 2020 :
    https://gofile.io/d/1yUqps - Carrier_policy.xml file from a Nord, seems o2 5G is supposedly enabled although I've yet to see it connect to it, that said the areas I've been in that are supposed to have 5G it was right on the edge of the 5G coverage so it may just be the case I wasn't close enough to a 5G mast.
  17. scarty16
    Donut Aug 8, 2020
    scarty16 , Aug 8, 2020 :
    Just changed to 3 today as I couldn't be bothered to wait for O2 and Oneplus to sort it all out. 5G settings appeared after I added the SIM.
  18. ankitmaity
    Gingerbread Aug 8, 2020
    ankitmaity , via OnePlus 8 , Aug 8, 2020 :
    Sub-6 5G? If you didn't spot any transmitters, it's probably that.
  19. feroze
    Froyo Aug 8, 2020
    feroze , via OnePlus 8 , Aug 8, 2020 :
    In the last couple of months, I've seen more coverage, especially in the City of London.
    I've had speeds up to 200 Mbps.
  20. W1599038094360
    Cupcake Sep 2, 2020
    W1599038094360 , Sep 2, 2020 :
    Hi mate, does the wifi calling work on o2 for the OnePlus 8 Pro? Thanks :)
