Oneplus 8 display horizontal lines via OnePlus 8
  1. N1596019562892
    Cupcake Nov 1, 2020
    N1596019562892 , via OnePlus 8 , Nov 1, 2020 :
    Horizontal lines appear when pinch in and pinch out is done on display, also if on low brightness and dark room when you see a wallpaper which is dull in nature , light horizontal lines appear all over the screen...attaching a wallpaper to your test too
    roserosh likes this.
  2. N1596019562892
    Cupcake Nov 2, 2020
  3. Snehu_IN
    Gingerbread Nov 3, 2020
    Snehu_IN , via OnePlus 8 Pro , Nov 3, 2020 :
    You say when pinch zooming or zooming out you see line's and that too in some particular lighting conditions, I think you are trying desperately to find some issue with the display, why? When you zoom or scroll in a dark environment and in the low brightness setting you will see some artifacts in all displays, but does it make a difference in the normal use case scenario. For example, you have a solid colour homescreen and in the lowest setting there are lines, spots, or colour changes then it is an issue.
  4. N1596019562892
    Cupcake Nov 3, 2020
    N1596019562892 , via OnePlus 8 , Nov 3, 2020 :
    Ok then have a look into this and tell me, am i nit picking as you say?? Does this looks normal to you?
  5. N1596019562892
    Cupcake Nov 3, 2020
    I am a night user, i read ebooks, i use dark theme and this issue is really bothering me..it feels like the pages have lines in then but distinct, as you say if i use more than 60% brightness these issue does not appear then, but its like i m pretending not to see these lines
  6. Snehu_IN
    Gingerbread Nov 4, 2020
    Snehu_IN , via OnePlus 8 Pro , Nov 4, 2020 :
    So this is how you normally use the phone, in a dark room with the lowest brightness and a Black/grey background? Comeon, that is what I'm saying. Under normal usage do you find these issues?
  7. Snehu_IN
    Reading in dark mode, is the app also in dark mode, like black background with white alphabets? Then I seriously suggest changing the habit because it causes the ultimate strain to your eyes. If you are reading for a longer time then it is better you have a white background with normal brightness.
    I'm not saying there are no issues, for me under normal usage scenarios I don't find any display related issues and when I tried the lowest brightness and a grey background in a completely dark room I found out that the screen is not displaying a uniform grey and I too start to think that there are some display issue, but then that usage scenario will never happen in my regular use and I have to particularly search for it.
    Searching for these issues which are not normal use case scenario will only spoil our peace of mind.
  8. Ash...Win
    Gingerbread Nov 5, 2020
    Ash...Win , via OnePlus 8T , Nov 5, 2020 :
    Yea for me on my oneplus 8t i can see Green tint on the right side of the display.especially on whatsapp dark mode,camera etc.
    Look ath the right side...raise brightness so u see it....i took ti on a avg camera phone so its not really that visible.
  9. N1596019562892
    Cupcake Nov 5, 2020
    N1596019562892 , via OnePlus 8 , Nov 5, 2020 :
    Check on YouTube search, in dark theme, I guess it appears more there..the screen is not uniform, I don't know why, taking premium price for abnormal behaviour of screen
  10. Ash...Win
    Gingerbread Nov 6, 2020
    Ash...Win , via OnePlus 8T , Nov 6, 2020 :
    Its not visible on YouTube search for me....its visible if u drag the notification tray and u can see the green tint on the sides...i sus that its not a green tint rather a defect bcz its visible on all brightness level
  11. emononop
    Eclair Jan 18, 2021
    emononop , via OnePlus 8 , Jan 18, 2021 :
    Seems like we all have some kind of issues. Now i am even scared to buy an AMOLED screen device again. Even iphone 12 pro max, Samsung Galaxy s20 ultra has this issue. I am looking forward to Micro LED display. I don't need deep black like OLED and get this kind of issues on my screen. I would go for less color accuracy but solid display. Even i am also facing some issue on my oneplus 8 though it's not something major. All the AMOLED screen comes with some issues. But still it's annoying.
    Ash...Win likes this.
