S1573742255080 , via OnePlus 8 , Jan 2, 2021 : My OnePlus 8 was draining battery nearly 10 percent at night time without using it can I get solution for this problem.
Tokolozi , Jan 2, 2021 : Usually this is caused by background apps. Battery statistics would be needed to figure out what is causing it. AOD can also cause additional drain of the battery. About 1% an hour sound about normal to be honest.
L1569940263579 , via OnePlus 8 Pro , Jan 4, 2021 : Got my phone 3 days back and having a very bad battery backup... previous phone 2 years old 6 t has better backup than the 8 pro....what should be done plz comment.
pgrey , Jan 4, 2021 : What @Tokolozi said, to start. Also, check your (mobile) signal, at your home location (NetworkCellInfoLite is my fave app for this). If it's low (say <110dBm), this can REALLY drain your battery, pretty much ANY mobiles' battery. It's a LONG industry problem, going back to the very beginning, pretty much...
RameshGhanta , via OnePlus 8 , Jan 20, 2021 : Yes bro happened to me even i tried keeping phone on flight mode still i haven't get any progress
