OnePlus 8 Pro - Display Colour Issues on Youtube via OnePlus 8 Pro
  1. priyanshubhateja , via OnePlus 8 Pro , Oct 15, 2020 :
    Hey guys,
    I was just wondering if anybody else is having some colour issues on YouTube. I first experienced an oddness in display colours while watching a random video on YouTube. I compared it with my Samsung Galaxy S8 and my suspicion was correct. I also noticed that when you exit the app and go to the settings to tinker around with display settings, it would automatically restore the correct colours. I literally switched comfort tone from off to on and back to off again and it restored the colours I desired. Is it some feature of OnePlus OS that it automatically changes colours or something as per some environmental conditions or some bug? I've posted the screenshots of both before and after the change. Let me know what you guys think!
    Rahil_Hastu likes this.
  2. coreslash
    Froyo Oct 16, 2020
    Best Answer
    priyanshubhateja likes this.
  3. Cheezburgers
    Honeycomb Oct 15, 2020
    Cheezburgers , Oct 15, 2020 :
    do u have vibrant colors on under display settings (the one that "enhances" colors in video)? might be that
  4. priyanshubhateja , via OnePlus 8 Pro , Oct 15, 2020 :
    I noticed that if I just exit the app a couple of times and open it again, it restores the colours.
    My settings for the display are
    Amoled Wide Gamut set right between cold and warm.
    Comfort tone off
    Vibrant colours off
    Motion smoothening off
    Full HD+
    120 Hz refresh
    No other modes like night mode or anything are on
  5. Thrillofit
    Froyo Oct 15, 2020
    Thrillofit , Oct 15, 2020 :
    I might believe I have something similar actually. This only happen whenever I got fullscreen. If I exit the fullscreen then the color is right but as soon as I enter the fullscreen, I can see sort of a grey/whiteish filter getting adding on the whole screen. Is it the same for you?
  6. priyanshubhateja , via OnePlus 8 Pro , Oct 15, 2020 :
    Hi! It's happening with me in general regardless of screen orientation. I've posted screenshots below for comparison. I just exited the app and went back on again to find this result. Hope it helps!
    BeingHumanSam likes this.
  7. Cheezburgers
    really weird, it might be bc the yt app is set to 60hz so the phone is switching btwn 60 and 120 when u open and close the app but otherwise not sure whats going on
  8. #8
  9. priyanshubhateja , via OnePlus 8 Pro , Oct 15, 2020 :
    Hi! So I set my screen to 60Hz refresh. Still the same problem! Comparison below
  10. #10
  11. Thrillofit
    Froyo Oct 15, 2020
  12. #12
  13. #13
  14. Thrillofit
    Froyo Oct 16, 2020
    Thrillofit , Oct 16, 2020 :
    Everything's okay in case of twitch. Hope the screenshots help!
    [/QUOTE]
    Hmm dont you at all get it? can you try to habe tje lowest brightness
  15. priyanshubhateja , via OnePlus 8 Pro , Oct 16, 2020 :
    ?[/QUOTE]Hi! Nope not with twitch. Brightness was at the lowest as well. Tried Netflix as well, it was fine too. Just YouTube
  16. Thrillofit
    Froyo Oct 16, 2020
    Thats superodd. For me this happens when I go fullscreen, basically the contrast is super bright only once I go fullscreen. Else its fine for me.
    What settings do you use so I can test the same?
  17. #17
  18. priyanshubhateja , via OnePlus 8 Pro , Oct 16, 2020 :
  19. Thrillofit
    Froyo Oct 16, 2020
