20
Display OnePlus 8 Pro Display Issue | Black Bar & Burn-in (image retention)
How many of you are facing similar display issue/s?
  1. Yes, facing similar display issues
    92.2%
  2. No, facing no display issues
    7.8%
  1. nimithnimmu
    Eclair Jul 21, 2020
    nimithnimmu , via OnePlus 8 Pro , Jul 21, 2020 :
    mine is manufactured on 13th July I'm facing the same issues. this is my third replacement unit. I'm fed up returning it
    #41
  2. H1595500337895
    Cupcake Jul 23, 2020
    #42
  3. DARKS7AR
    Froyo Jul 23, 2020
    DARKS7AR , Jul 23, 2020 :
    It neither, You are actually seeing the refracted light which appears to be green on the edges. If you wanna test your device with green tint. Use the attached image and gradually decrease your brightness from 25% to minimum
    #43
  4. H1595500337895
    H1595500337895 , Jul 23, 2020 :
    There are lines present if you see on the display I can see it on any color , let me also share the results with that image
    #44
  5. H1595500337895
    #45
  6. H1595500337895
  7. Dipankar_verma
    Eclair Jul 24, 2020
    Dipankar_verma , via OnePlus 8 Pro , Jul 24, 2020 :
    nimithnimmu
    mine is manufactured on 13th July I'm facing the same issues. this is my third replacement unit. I'm fed up returning it​
    You going to replace it again or going to live with it,?like i replaced ones got the same black bar,black crush issue its almost with every device
    #47
  8. Dipankar_verma
    Eclair Jul 24, 2020
    I do face the same lines on the display mostly visible watching stories on instagram but it doesn't matter to me like playing games watching movies nd stuf its not visible
    #48
  9. H1595500337895
    Cupcake Jul 24, 2020
    H1595500337895 , Jul 24, 2020 :
    I have returned this phone, the other phone I have same oneplus 8 pro, 12gb variant, only have that punchhole blackbar visible on very low brightness and on only dark colors,
    #49
  10. Dipankar_verma
    Eclair Jul 25, 2020
    #50
  11. Z1596256230281
    Cupcake Aug 1, 2020
    Z1596256230281 , Aug 1, 2020 :
    Hello guys,
    In the past 2 months I had in my hands around 20 phones so I can tell that green tint issue is problem of almost all new and previous generation OLED panels. But some devices were perfect.
    Here is the example:
    Samsung Galaxy S20 - 3 devices with very visible green tint on top right side, 1 device with perfect screen.
    Samsung Galaxy S20 Plus 5g - 1 device without green tint but with very small screen retention (really hardly visible)
    OnePlus 7t - 2 devices with very visible green tint on top side of screen
    OnePlus 8 - no green tint but very visible screen retention
    OnePlus 8 Pro - small green tint, no screen retention
    Google Pixel 4XL - 2 devices with visible green tint
    Huawei P40 - display from BOE, very visible green tint on bottom side
    Xiaomi Mi 10 - perfect display
    Xiaomi Mi 10 lite - hardly visible green tint but it's there
    iPhone 11 Pro Max - hardly visible green tint but it's there
    *Green tint - visible on grey background when brightness set less than 30%
    *Screen retention - my way of testing - I set brightness on around 60%, open home screen with icons on it, wait 30 seconds and then open Google Chrome with dark mode.
    Most of the green tint issues can be solved by setting display to 60HZ. I tested it and it really made a big difference on 80% of devices. Especially on Samsung devices when they were set on 120HZ I could see very visible green tint but when set to 60HZ it was almost completely gone.
    #51
    F1593081263650 and Samsakthi like this.
  12. Samsakthi
    Gingerbread Aug 2, 2020
    Samsakthi , via OnePlus 8 Pro , Aug 2, 2020 :
    Speaking of black crush, it happens only when HDR content is played on Netflix. Similar dark HDR content from YouTube plays smoothly. So I guess black crush occurs due to some kinda mis-calibration.
    #52
  13. Z1590338714936
    Cupcake Aug 2, 2020
    Z1590338714936 , via OnePlus 8 Pro , Aug 2, 2020 :
    Anyone facing issues on WhatsApp? For me, the screen goes blank while switching between WhatsApp call screen and other apps. Also, while checking the status again the screen goes blank.
    #53
  14. O1596809182326
    Cupcake Aug 7, 2020
    O1596809182326 , via OnePlus 8 Pro , Aug 7, 2020 :
    pls help me how did you returned the OnePlus 8 pro.... even I want a replacement ..pls help
    #54
  15. O1596809182326
    Cupcake Aug 7, 2020
    I am facing display issue in OnePlus 8 pro . After only 6 hours of purchasing the phone I can see the green tint issue , black crush , black dark patches etc .
    Please help me how can I solve the problem. Can I get a replacement/refund of my product. Please help me out with this OnePlus .
    #55
  16. akkukazi
    Cupcake Aug 7, 2020
    akkukazi , via OnePlus 8 Pro , Aug 7, 2020 :
    I'm facing black bar issue and it's July 2020 unit
    #56
    ghrer likes this.
  17. Aakash_07
    Cupcake Aug 16, 2020
    Aakash_07 , Aug 16, 2020 :
    did you buy it?, i bought it last week and have some issues
    #57
  18. hyperati
    Froyo Oct 23, 2020
    hyperati , via OnePlus 8 Pro , Oct 23, 2020 :
    Yes I bought it yesterday and still image retention exists at high brightness.
    #58
