Display OnePlus 8 Pro: eyes strain, fatigue, headache
  1. G_Pavel_Bychikhin_hfYP
    Cupcake Jun 17, 2020
    G_Pavel_Bychikhin_hfYP , Jun 17, 2020 :
    Hello,
    I've recently purchased OnePlus 8 Pro 12/256GB and after few days found I feel eyes strain, fatigue and headache while looking at its display.
    No matter which refresh rate, resolution, color calibration I use.
    120hz refresh rate seems to be even worse than 60hz in terms of eyes strain.
    DC dimming doesn't seem to help. I'm not sure if it changes anything at all. Only color tone becomes slightly different.
    My previous OnePlus 6T works just fine. Its display is perfect in terms of eyes comfort.
    OnePlus, can you please help me to solve the issue with OnePlus 8 Pro? Some firmware update?
    Hiro296 likes this.
  2. Denny.jose
    Cupcake Jun 26, 2020
  3. Ozymandias_Osiris
    Honeycomb Jun 27, 2020
    Ozymandias_Osiris , via OnePlus 8 Pro , Jun 27, 2020 :
    Don't think the display is the issue,well in general displays aren't that great for the eyes,but I feel that you're eyes are more sensitive, personally don't have any issue. Did you try using night mode to see if its better to the eyes?I always use this option at night,its better for my eyes.
  4. G_Pavel_Bychikhin_hfYP
    Cupcake Jun 30, 2020
    G_Pavel_Bychikhin_hfYP , Jun 30, 2020 :
    Over last few weeks I've got used to the new display. So its flickering is no longer a big issue. Moreover, I've tested it with a pulse meter, and it turns out that 8 Pro has even better display than 6T in terms of flickering. Don't know why I feel the 6T's display is more comfortable for eyes.
    Anyways, OLED displays are not as good for eyes as they should be. Don't know if it is only OnePlus issue or this is the case for all phone manufacturers. Hope some day we'll get true flicker free OLED.
  5. G_Kishore_Jain_aEua
    Cupcake Jul 21, 2020
    G_Kishore_Jain_aEua , via OnePlus 8 , Jul 21, 2020 :
    which screen calibration you're using now? I got the same problem on OnePlus 8
  6. G_Pavel_Bychikhin_hfYP
    Cupcake Aug 13, 2020
    G_Pavel_Bychikhin_hfYP , Aug 13, 2020 :
    I'm using Screen calibration Natural and Comfort tone
  7. Carlewis
    Cupcake Sep 25, 2020
  8. Hiro296
    Cupcake Oct 8, 2020
    Hiro296 , Oct 8, 2020 :
    It's the hardware problem and the display is too bright.
  9. J1546178651674
    Cupcake Dec 28, 2020
    J1546178651674 , Dec 28, 2020 :
    I'm having the same problem but this is with the 8T.. I had no issues with my 6t .. now eyes strain, headache and it's not getting better ..
  10. Sai_swaroop
    Cupcake Jul 25, 2021
    Sai_swaroop , Jul 25, 2021 :
    Broo same here bro something is wrong lets complaint bro seriously, I noticed after using months eyes get strain , light headaches , dark circles , something is definitely wrong with the display 100percent
  11. N1634575804925
    Cupcake Dec 7, 2021
    N1634575804925 , Dec 7, 2021 :
    Has anyone found a solution to the eye strain problem. I had an old iphone 7 before OnePlus and it was so much easier on my eyes. I find my eyes hurting with a headache a few minutes after I look at my oneplus 8T plus. I really thought the bigger screen makes it easier on my eyes but it was completely the opposite. Has anyone found a solution?
