2
OnePlus 8 Pro Rattling?
  1. Cannuh
    Cupcake Apr 25, 2020
    Cannuh , Apr 25, 2020 :
    I'm maybe going crazy here and looking for a fault over nothing. I believed this noise was initially just the lenses/OIS floating around in the phone but it sounds really aggressive. I took a video shaking the phone lightly in which something moving inside can be heard.
    Can anybody input anything in to this before I send it to an unscrupulous company in Poland for repair/returns?
    https://drive.google.com/open?id=1-TijPkcRlpTcVUAdKs_5-GjnYvEwd8Nn
  2. Smil
  3. realsherban
    Eclair Apr 25, 2020
  4. B1587150983537
    Cupcake May 21, 2020
    B1587150983537 , May 21, 2020 :
    I have experienced the same fault since obtaining the phone... I returned it to Poland and got a new replacement. However, the replacement has the same issue, thus, sadly I don't think its worth anyone returning as it seems all Oneplus 8 pros have the same problem.
  5. Deactivated User
    Jul 19, 2020
  6. Deactivated User
    Jul 19, 2020
  7. shantanusinghyo
    Cupcake Jul 22, 2020
  8. AndrewMsd
  9. C1596187702463
    Cupcake Jul 31, 2020
  10. Decktec
    Cupcake Aug 11, 2020
  11. wwickedd
    Cupcake Aug 12, 2020
  12. anilkigal
    Ice Cream Sandwich Aug 14, 2020
  13. N1597397126167
    Cupcake Aug 21, 2020
  14. Fzmd15
    Cupcake Sep 9, 2020
  15. Fzmd15
    Cupcake Sep 9, 2020
  16. Ptaswath
    Eclair Sep 16, 2020
  17. YashDhagat
    Cupcake Sep 17, 2020
    YashDhagat , via OnePlus 8 Pro , Sep 17, 2020 :
    It's happening with me as well. At first, I didn't notice it but now it's making me crazy. Feels like some part is loose inside the phone or the built quality is very low or something!
    @onepluscreater #oneplus8pro #faulty #needfix #onepluscommunity #oneplus
  18. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 17, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 17, 2020 :
    I don't know the level of rattling for all of you... But if you ever seen a teardown you probably noticed that the optical stabilisation of the camera lenses makes the lenses move when they poke at them.
    You can actually verify it by opening camera. First use wide angle lens. Shake near ear. Then switch to main lens. You probably hear different sound depending on what lens that is active.
    BoutTime likes this.
