[Answered] OnePlus 8 Pro Slow Warp Charging
  1. revanth_reddy_r , via OnePlus 8 Pro , Jul 17, 2020 :
    Bro all those who are suffering from slow charging need to do 3 things
    1. Factory reset your phone
    2. After factory reset ,First turn off the optimised charging feature and bed time mode feature
    If it didn't work after the first two steps then try 3rd one
    3. Clear cache and enter into the safe mode and then charge the phone .
    Steps to clear cache and to enter safe mode check out the pic
    Definitely I hope first two steps will solve your problem for sure . It worked for me .
    prajual likes this.
  2. prajual
    Cupcake Aug 2, 2020
    prajual , Aug 2, 2020 :
    Hey, I've tried doing it but still, it's very slow. and hasn't improved a bit
  3. revanth_reddy_r , via OnePlus 8 Pro , Aug 2, 2020 :
    Yes bro even I'm facing this slow charging issue after the oxygen os 10.5.12 update
  4. prajual
    Cupcake Aug 7, 2020
    prajual , Aug 7, 2020 :
    Looks like we'd have to file a law suit against OnePlus. Very disappointed :mad:
  5. TheMani
    Froyo Aug 11, 2020
    TheMani , via OnePlus 8 Pro , Aug 11, 2020 :
    I have the same issue it took me 1.50 hour to charge my phone from 3% to 100
  6. premmehu008
    Cupcake Aug 20, 2020
  7. qvert
    Honeycomb Oct 11, 2020
  8. Easwaran_G
    Cupcake Oct 16, 2020
    Easwaran_G , via OnePlus 8 Pro , Oct 16, 2020 :
    Finally my issue is resolved ! ! ! !
    The problem is with the cable. I got free replacement covered under warranty. said:
    if you face the same issue, first troubleshoot the issue in below steps.
    1) Charge other phone with this charger and check the voltage with Ampere App. if it is normal check with other 1+ device which supports Warp.
    2) If it charges slowly, change the cable (try ur frnds cable) in ur adapter and check in your 1+ and other phone. ( note the Ampere)
    3) If cable change still doesn't increase Ampere value, use your frnds other fast charger. (NOTE : U won't get 30W charging with other cable than 1+)
    4) If none of the above steps working, reset ur phone, clear launcher cache and try.
    5) If still not working, take ur 1+ to near by 1+ experience service center.
    My 1+8 pro was just 35 days old when I face this issue. I took to chennai 1+ experience store and they replaced quickly. Hassel less solution.
    pradhyubandari likes this.
  9. O1599531902234
    Cupcake Oct 25, 2020
    O1599531902234 , Oct 25, 2020 :
    I have updated my OnePlus 8 to oxygen 11 yesterday. It is charging very slow now. Please provide a fix
  10. W1603036284348
    Cupcake Jan 22, 2021
    W1603036284348 , Jan 22, 2021 :
    I am facing this issue from 3 months, been to the service center several times they have replaced the charger, data cable and the battery still the issue persists i don't know what else to do now
  11. P1614527569341
    Cupcake Mar 3, 2021
