198
OnePlus 8 Pro Users - Vote for Photochrom Filter to work like Original
Do you want Photochrom Feature Like original ?
  1. YES
    95.3%
  2. NO
    2.2%
  3. I am happy without of it
    2.5%
  1. SteveCP likes this.
  2. sonnettie
    Froyo Aug 1, 2020
    sonnettie , via OnePlus 8 Pro , Aug 1, 2020 :
    I'm in UK and had the update weeks ago, I'm on three, I've not updated but, I've paused it lol, till I find a way to disable the IR camera block
    SteveCP likes this.
  3. sonnettie
    Froyo Aug 1, 2020
    By the way what version you got, as most peep in UK have got the better version the IN2023, doesn't have the display problems etc, but not all of us maybe your one of the few that's got the cheaper us variant?
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 1, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 1, 2020 :
    Google adb photochrom and lock the app for constant access.
    Better than avoiding updates
    SteveCP likes this.
  5. SteveCP
    Jelly Bean Aug 1, 2020
  6. inteks
    Donut Aug 1, 2020
  7. sonnettie
    Froyo Aug 1, 2020
    TO be honest I don't want to use factory mode workaround, I want a edited APK or even just after updating replace the new APK with the original, just wanted to know what was done to block it? Is it in the camera APK, the system UI, some config file, or is it a blocking APK etc, how far did they go to block it, does anyone know for def what file was changed/updated, and will replacing it work? Is the new APK better than the old one or just the same except the removal of the IR lense, and if it is better I'm what way? Is it just an subroutine in the program to use the main camera, add the (software) filter, and use the IR lense as an on/off switch, this is what I suspect, and if so will using the old apk in the new update work or is there a test in the main UI for the old APK and if so is it just a simple if test on the APK version or is it encrypted test, will the main UI need to be edited/replaced too? Anyone? Any light in the matter? I just want to be able to click on the filter if needed, quick and easy, like if I see a hot chick and need to activate my trusty x-ray cam fast to see her naked before she escaped away, kidding lol, but seriously I don't want a half working complicated work around, it's not that importand, I just want it to be there if I need it, as simple as it is now but I also want to be able to update without rooting as I've heard unlocking the BL can reset your fingerprint sensor calibrations etc in the "persistent" partition, I now you can DD the part and re DD it back but I'd rather mot,.
  8. Swejuggalo
    Both apk and at camera processing system level. Simply an edited apk probably don't work.
    GCam can use the lens too, but rooted and a magisk module.
    For me it's a work related tool (to see IR). For photos if I'm forced to use the filter I actually prefer the new one...
    sonnettie likes this.
  9. sonnettie likes this.
  10. sonnettie
    Froyo Aug 1, 2020
  11. sonnettie
    Froyo Aug 1, 2020
  12. Swejuggalo
    There already is. GCam (root and module) and the adb trick (no root) . (Google adb photochrom and lock the app so it never closes).
    Other phones can use this (root).
    https://play.google.com/store/apps/details?id=com.joaolvcm.pocoseccamera
    Maybe something similar could exist for Oneplus but probably demands root. Might as well use the adb method then.
    S1592697441346 likes this.
  13. Swejuggalo
    I guess it could be possible to have a 3rd party rom with modified stock camera components built in. XDA would probably be the best source of info for that. Many different posts for various roms there.
  14. sonnettie
    Froyo Aug 1, 2020
    Yeah I get what you're saying but gcam is a general camera app not build to use specific features and calibrations of certain cameras, ie ours, what I want is to have the option if I need/want it, but not to have to compromise other features/qaullty/ease of use, simply put I want to just remove the block lol, also I've heard the ADB workaround just enables the factory ver of the app and restricts usage/quality/features etc, is this true or am I misinformed, I would hope so, as that be exactly what I'm looking for, if, that is, it just worked like the the current/old APK with the new update
  15. S1592697441346 , via OnePlus 8 Pro , Aug 1, 2020 :
    Swejuggalo
    Maybe something similar could exist for Oneplus but probably demands root. Might as well use the adb method then.​
    Good info. But I mean, someone out there has to have the programming prowess to make an app called "OnePlus 8 Pro Photochrome" that reestablishes the full functionality of the photochrome camera, as it existed when it first came out, then put it in Google Play Store, sell it for 99cents. I'd buy it immediately. Would even pay an extra dollar to have video functionality as well. There is a need, and therefore an opportunity. If OnePlus isn't going to do it, then someone should take the opportunity and run with it.
  16. Swejuggalo
    The adb solution have video support with that lens...
    Anyway... If we get such an app it might be a root app
  17. Swejuggalo
    It a factory mode app that allows testing of all lenses... Taking photos and even making videos with the 4th lens...
  18. Swejuggalo
    Until some other easy solution comes up I simply have it always locked here. It remains accessible even after reboot. You only need adb once.
    sonnettie, SteveCP and S1592697441346 like this.
  19. sonnettie
    Froyo Aug 1, 2020
    And does it work exactly the same after your run the ADB sh script? Or is there limitations? Is does the camera still work the same, still full screen, same functions etc? Just sounds too easy why is everyone not just doing that? Or is it just not that we'll known?
  20. Swejuggalo
    When you run the adb command a extra app opens. Use that for the color filter lens features. Then just use regular camera app for all the normal stuff. Nothing lost by doing it.
    Just lock that extra app and you never need to launch it via adb again.
