198
OnePlus 8 Pro Users - Vote for Photochrom Filter to work like Original
Do you want Photochrom Feature Like original ?
  1. YES
    95.3%
  2. NO
    2.2%
  3. I am happy without of it
    2.5%
  1. E1594214227258
    Cupcake Jul 17, 2020
    W1593412684289 likes this.
  2. W1593412684289 , via OnePlus 8 Pro , Jul 18, 2020 :
    Yes either the photocrom camera should be bring back or some percent of our money should given back to us. We have actually paid full amount for this phone. Logically if there is no camera so refund should be given.
    My support for this post 100%.
    Larryhicks0302 likes this.
  3. Am_Vks
    Gingerbread Jul 18, 2020
    Am_Vks , via OnePlus 8 Pro , Jul 18, 2020 :
    So my x-ray camera is back
    For those who would like to keep high hopes on X-ray. It's gonna dissepoint you. Because it only works on a very thin plastic /fabric under "good enough" sun light. Artificial lighting makes it little blueish tint. Secondly, I tested on other remotes in the house from same standing point. Sorry to say, the so called "X-ray" does not work. In conclusion requires very very thin opaques.
    Second experiment was out doors
    The above image is from the fourth Camera it-self
    This above image is taken from same position using current updated photochromic filter
    Taken from 4th camera
    Taken from same position from updated photochromic filter
    In conclusion: since the road is shaded with trees from three sides, I was having very hard time to take photochromic pictures in the new updated camera. This "SERIOUSLY" need to be fixed
    Second of all. Like I used to say before.. the old photochromic camera can take pictures indoors with fair amount natural light. And can give out more depth to the pictures. While the latest update captures more details thanks to 48mp camera but less natural. Hope this can give more light on the current ongoing topic
    PS- tried X-ray on my thinnest cloth.
    Lays packet is visible in normal camera, while......
    X-Ray magic does not happen ☹️
    Viraj Pnvs, Afsilvas and Avishek2882 like this.
  4. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Jul 18, 2020
    mojoyoyo77 , Jul 18, 2020 :
    It still works like before, with some black plastics and crystals, it never worked with clothes, that was a big lie
  5. mojoyoyo77
    With a computer and adb it is faster and easier
  6. Dave8pro
    Eclair Jul 18, 2020
    Dave8pro , via OnePlus 8 Pro , Jul 18, 2020 :
    Yes, but you can't carry computer with you all the time🤔 and with the script you can call the camera factory mode everywhere with one word
    mojoyoyo77 likes this.
  7. mojoyoyo77
    You can block the app in "recent", but if you restart the device ... you lost it, yes
  8. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 18, 2020
  9. mojoyoyo77
    You mean Termux and ADB, when you say it holds the reboot?
  10. Avishek2882
    Froyo Jul 18, 2020
  11. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 18, 2020 :
    Normal adb via cable. Lock the app for easy access. Open via recent apps after reboot. Launcher keeps recent apps even after reboot. Locked or not. It remembers them if you haven't closed them manually
  12. Swejuggalo
    Termux and ADB works the same. I have some issues getting wireless debugging going though. Took a long time to get adb devices to actually find the device.
  13. mojoyoyo77
    Yesterday I did it with adb shell and this morning it was gone, I did it again and this time I blocked it, I tried to restart and continued along with other applications, incredible, this is very good
  14. mojoyoyo77
    Better wired, with wireless connection you risk mistakes, wireless debugging has rooter as broker
  15. Swejuggalo
  16. derLenno
    The Lab - OnePlus 6 Reviewer Jul 18, 2020
  17. mojoyoyo77
    These types of images are perfect to scare the gardener, you send him the photo and you say: what did you do during my vacation? :p:D:p
    Swejuggalo likes this.
  18. Swejuggalo
    You mean wireless adb and commands via Termux is less restricted? If something needs root you still need root to do it... So wireless adb does not override anything wired adb can't do as far as I know.
  19. mojoyoyo77
    I don't mean cable vs wifi. In theory they work the same, but with the wifi there is an extra risk, for these things I prefer the cable
  20. Swejuggalo
    Yeah. Strongly advice to turn it off when not needed anymore. The slow startup it has is annoying though. If the wait for it to work wasn't that long you could simply just enable. Do what you need on the phone and then disable. And after a reboot it's disabled by default. As it is now wireless adb isn't as quick and handy as I want it to be.
