6
Oneplus 8 PRO Volte issue
  1. M Mihai Tudor
    Froyo Dec 8, 2020
    M Mihai Tudor , Dec 8, 2020 :
    @G_Антон_Русинов_qQub:
    As drivers for the 3 unknown devices in Device Manager I tried with: Qualcomm HS-USB Modem 90E5 and QUALCOMM HS-USB WWAN Adapter 9091. What drivers worked for you? Could you please provide printscreens with your device connected to the PC after first step adb reboot ftm?
    #41
  2. M Mihai Tudor
    Froyo Dec 8, 2020
    Best Answer
    #42
  3. M Mihai Tudor
    Froyo Dec 8, 2020
    I found all the drivers that the PC requires when I reboot in FTM mode. I attached them here, if anyone needs them. After installing them, PDC still does not see my phone in Device list.
    #43
  4. G_Антон_Русинов_qQub , via OnePlus 8 Pro , Dec 8, 2020 :
    1. install Logkit v1.0.apk, and Engineering Mode v1.01.0.171117173719.apk
    2. Open Phone and type *#800# select Engineering Mode
    3. Oneplus Logkit ---> Function Switch ---> enable VoLTE, VoWifi и VT
    4. Reboot
    5. Open settings and enable VOLTE and voWi-fi
    6. Open Phone and type *#801# select Engineering Mode
    7. Switch to full port switch
    8. Open settings and enable debugging by usb mode
    9. adb reboot ftm
    10. adb shell
    11. setprop sys.usb.config diag,diag_mdm,qdss,qdss_mdm,serial_cdev,dpl,rmnet,adb
    12. Open PDC and select profile ( sub0 and sub1 then click activate for VoLTE PTCRB for example)
    13. Close PDC
    14. adb reboot
    Full instructions:
    https://forum.xda-developers.com/t/working-force-enable-volte-vowifi-on-op7-pro.3934227/page-26
    Use adb tutorial for PDC connection. Very simple, I get Volte and voWi-fi via Android 11.0.2.2 IN2020.
    #44
    glideleo likes this.
  5. G_Антон_Русинов_qQub , via OnePlus 8 Pro , Dec 8, 2020 :
    Full port switch and debugging via usb can help you. Just read my previous post.
    #45
  6. glideleo
    Donut Dec 9, 2020
    glideleo , via OnePlus 8 Pro , Dec 9, 2020 :
    I have problems in VoLTE activation. I make all steps, but in PDC inform about error "*******connect to device failed" (photo from 4pda, my error the same)
    #46
  7. #47
  8. glideleo
    Donut Dec 10, 2020
    glideleo , via OnePlus 8 Pro , Dec 10, 2020 :
    Я был прав - не надо там full port switch)) Проблема в том, что графический клиент PDC кривой, видимо, какие-то тайминги портов модема срабатывают раньше, чем он получит ответ и вылетает ошибка связи.
    Решение простое: до запуска PDC запускаем EFS Explorer, выбираем свой телефон и заставляем его читать файлики. Он это делает сильно долго, а паралельно с ним работает и PDC (хоть и отвечает долго)
    #48
  9. G_Антон_Русинов_qQub , via OnePlus 8 Pro , Dec 12, 2020 :
    Добавил в инструкции на 4PDA, в общем у нас уже есть большой пост про Volte и voWifi, который поможет запустить их на любой OOS.
    #49
  10. glideleo
    Donut Dec 12, 2020
    glideleo , via OnePlus 8 Pro , Dec 12, 2020 :
    Отлично, спасибо Чуть поясню - PDC надо запускать сразу, пока EFS Explorer читает список файлов(чтение списка файлов длится минут 5, соответственно, связь с телефоном не разрывается и с pdc проблем нет).
    Кстати, в папке с pdc есть его консольная версия, так что переключение профиля можно вообще скриптом сделать
    #50
  11. AbbasiG
    Froyo Dec 12, 2020
    AbbasiG , via OnePlus 8 , Dec 12, 2020 :
    I tried and it worked,opened PDC parallel with EFS explorer, and valla pdc opened,before it was giving error(connection to device failed)
    #51
  12. itzal
    Cupcake Dec 26, 2020
    itzal , via OnePlus 8 Pro , Dec 26, 2020 :
    Hello
    Same problem here in Spain. NO VOLTE AND NO VOWIFI, even when switched on in the sim settings menu.
    OnePlus 8 pro in2020 in MOVISTAR, stock ROM with last update
    Neither 5g is working at all.... 😖😖😖
    Waiting for a oneplus solution!!
    #52
    PippoPD likes this.
  13. PippoPD
    Cupcake Jan 2, 2021
    PippoPD , Jan 2, 2021 :
    OP 8 Pro in2023 with last stock rom.
    Italy with WindTre operator.
    No 5G and no Volte :mad:
    oneplus, where is the firmware that solves these problems?
    When will a patch come out?
    Thanks.
    #53
  14. G_Антон_Русинов_qQub , via OnePlus 8 Pro , Jan 7, 2021 :
    Bro, just use tutorial from head of this topic for activation Volte and voWi-fi. If you want to activate 5G, you need to find tutorial via youtube, I have seen how the one of France guy do it very simple for 1+ 8T.
    #54
