Gensosan , via OnePlus Community App , Apr 16, 2020 : Hi there, is there a chance to turn off VoLTE? I don't find the position in the settings. What's the matter here?
dazkgoodwin , Apr 17, 2020 : I can't find the option to turn it on anymore, it used to be there on my OnePlus 6
dazkgoodwin , Apr 25, 2020 : That's the same for everyone (data dropping on calls), as 4G/LTE is a data only network so it falls back to 3G for calls, hence why they introduced VoLTE - I've noticed that VoLTE does work in the UK on Plusnet mobile 4G, so it's probably just a matter of time waiting for the network to support the device. In the UK, Three are selling the OnePlus 8 Pro, so I'd imagine they will be supporting VoLTE soon.. or I hope!
chistery , Apr 28, 2020 : Following the same method for the 7Pro, you can enable VoLTE and VoWiFi for the 8 Pro. Confirmed it works fine on Vodafone UK now.
dazkgoodwin , via OnePlus 8 Pro , Apr 28, 2020 : No, still can't get it to work. Total mystery. Works fine on OP6. Can you repost article or link to instructions please as there's so many threads it's hard to find the one which might resolve it. Thanks
chistery , Apr 28, 2020 : I followed this... https://www.theandroidsoul.com/how-to-enable-volte-and-vowifi-on-oneplus-7-pro/
dazkgoodwin , via OnePlus 8 Pro , Apr 28, 2020 : Thanks, unfortunately there is no VoLTE or VoWiFi options under the logkit - > function switch menu. Anyone else on Three have VoLTE working?
chistery , via OnePlus 8 Pro , Apr 28, 2020 : have your installed the APK package? you should then get the options.
dazkgoodwin , via OnePlus 8 Pro , Apr 28, 2020 : Have installed. Ticked options but still neither coming to life after reboots. Very frustrating! 🙁
chistery , via OnePlus 8 Pro , Apr 28, 2020 : have you also enabled WiFi calling under the SIM settings? not sure why VoLTE doesn't work. Does it work in another phone?
Raggaboi , Apr 29, 2020 : Hi, I am in the same position as dazkgoodwin, I have installed the latest logkit, enabled VoLTE (and VoWiFi even though the option was there already and can confirm VoWiFi is working) and tried to enable it in the settings, but yet it does not show. However I have noticed that my icon says 4G+ and when I make a call it doesn't drop to 3G either, but it does not explicitly state VoLTE is active or any indication of enabling/disabling it. Any advice on whether this is how it's supposed to work now or? TIA
dazkgoodwin , via OnePlus 8 Pro , Apr 29, 2020 : Yes WiFi calling enabled, just not working. Vowifi and VoLTE both work with my SIM in oneplus 6.
dazkgoodwin , Apr 29, 2020 : Interestingly, I've put my SIM back in my OnePlus 6, VoWiFi is not showing, whilst VoLTE is popping on and off the status bar, but the main thing is that there are no switches in the LogKit on that phone for VoLTE or VoWiFi but it does work. Under the SIM & Network setting, and selecting SIM1, VoLTE is a switch option, whereas it's not on the OnePlus 8 Pro. Perhaps Three still need to fully enable it for this handset still as they did on the OP6 as neither were available out-of-the-box on that handset either.
dazkgoodwin , Apr 29, 2020 : Hopefully over time it will sort itself out, though not sure what my options are if it doesn't, perhaps I'll contact Three, but will give it more time as the handset is so new.
JasperDelahaije , via OnePlus 8 Pro , Apr 29, 2020 : chistery I followed this... https://www.theandroidsoul.com/how-to-enable-volte-and-vowifi-on-oneplus-7-pro/ I had the same problem. I'm from the Netherlands and using the Tele2 network. When I used the preinstalled logkit on the OnePlus 8 Pro the VoLTE switch does not show up and neither does the VoWi-Fi, but when I installed the APK from the link, the switches do show up and now I do have a VoLTE logo at the top of my screen and it seems to be working. So when I followed the steps in the link it worked for me.
