2
OnePlus 8 Pro VoLTE
  1. mariusmuntensky
    Froyo May 31, 2020
    mariusmuntensky , May 31, 2020 :
    For 5G I have the same problem, I cannot select it in Settings beause there is no option, only 2g/3g/4g. You can enable the 5G by using the 4G Fix app from play store. There, in the network mode, you select the NR/LTE/TDSCDMA/GSM/WCDMA option instead of the current one.
    #61
  2. CataPuscas
    Cupcake May 31, 2020
    CataPuscas , via OnePlus 8 Pro , May 31, 2020 :
    Yeah but it changes back after a phone restart..
    #62
  3. U1592403434958
    Cupcake Jun 17, 2020
    U1592403434958 , Jun 17, 2020 :
    Thanks to all who have posted information on here. VoLTE and VoWIFI worked out of the box on my OnePlus 7 Pro 5G so I couldn't understand it when my new OnePlus 8 Pro (Chinese version with Google Apps loaded) did not seem to have the feature. I had never heard of the Logkit but from the instructions and links posted here have been able to successfully activate both features for the phone which is using a Vodafone SIM. I am UK based and now have VoLTE and VoWIFI working on Three SIM (Pro 7 5G) and Vodafone SIM (Pro 8).
    #63
  4. iKomeyl
    Cupcake Sep 4, 2020
    iKomeyl , Sep 4, 2020 :
    What model oneplus 8 pro do you have?
    IN2020 or IN2025 or IN2023?
    #64
  5. ziby009
    Cupcake Jan 16, 2021
    ziby009 , Jan 16, 2021 :
    [Solved]
    I have rectified my Volte issue
    Model: Oneplus 8t
    Please follow this link:
    #65
    Y1599469094303 and fernoct like this.
  6. devmittal29
    Honeycomb Jan 16, 2021
    #66
  7. happiboi
    Gingerbread Jan 16, 2021
    happiboi , Jan 16, 2021 :
    I have IN2020
    #67
    goran_oh likes this.
  8. fernoct
    Cupcake Mar 6, 2021
    fernoct , via OnePlus 8T , Mar 6, 2021 :
    Thanks a lot buddy. I'm new to OnePlus and no VoLTE gave me headaches and frustrated buying this. Here came the rescue :)
    #68
    ziby009 likes this.
  9. S1616276547926
    Cupcake Apr 8, 2021
    #69
