OnePlus 8 volte setting missing oos 11.0.8.8IN21AA via OnePlus 8
  1. P1622178990937
    Cupcake Oct 18, 2021
    P1622178990937 , via OnePlus 8 , Oct 18, 2021 :
    Hey OnePlus,
    I am in Malaysia and have been using my oneplus 8 since it is in oos10 and the volte works normally. But once i update it to oos11, the volte is unusable and the volte and vowifi setting options are missing. Until now (oos 11.0.8.8IN21AA), the issues still presists. I won't be believe it is a issue with the service provider because before oos11 it works flawlessly. Please take note and address this issue immediately in the next OTA.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Oct 18, 2021
    Caomhin , via OnePlus 9 Pro , Oct 18, 2021 :
    You must have a network provider who provides the VoLTE/VoWifi service on your mobile plan.
    The VoLTE/VoWifi settings will be in your Sim & Network settings, if its not showing and you have a Network provider that supports it as well as a good 4G LTE signal then try the following to see if this will enable it.
    This is for all OP phones, however it discuses the 8 Series, but it should apply to any series as the protocols are the same.
    [GUIDE] Enable VoLTE & VoWiFi on all devices NO ROOT.
    https://forum.xda-developers.com/on...nable-volte-vowifi-devices-root-t4105817/amp/
    Log Kit 1.0
    https://www.apkmirror.com/apk/onepl...ase/onepluslogkit-1-0-2-android-apk-download/
    There are newer versions but I would suggest trying this with the details provided on XDA.
  3. P1622178990937
    I am 100% confirmed that my network provider support volte and vowifi because i can use it before i update to oos11. Doing such configurations are so frustrating, why don't just let oneplus solve this issue in coming OTA? Other smartphone brands just fix it directly for their users.
  4. Caomhin
    No idea why it's not working for you, however try the steps mentioned and see if it works for you.
