OnePlus 8t battery performance via OnePlus 8T
  1. T1599186531566
    Cupcake Feb 27, 2021
    T1599186531566 , via OnePlus 8T , Feb 27, 2021 :
    Hi, I've just received my OnePlus 8t and was worried about the battery life from the start of setting it up, during the set up it lost 5% of battery (it only took 5 mins) I have seen countless reviews about this phone saying the battery life is amazing, but from only using it for the past 4 hours I'm a little worried.
    At 93% the battery app said 5hrs left
    At 90% it's 6hrs left ?
    Did a little test if that helps: 12 minutes of gaming used 5% - 60fps, brightness 3/4, sound 1/2
    Now at 84% saying 5hrs again
    For reference my previous phone is a Huawei mate 20 pro
  2. Artemus.
    Community Hero 2020 Feb 27, 2021
    Artemus. , Feb 27, 2021 :
    That's completely normal for the battery to drain faster than usual the first time. During the process, the phone is doing a lot of background processes getting everything working after lying dormant for who knows how long. This is also why it feels warmer than usual and is also completely normal. Once you get it up and running and the battery learns your usage habits it'll start to stabilize and run more efficiently.
    T1599186531566 likes this.
  3. T1599186531566
    Thanks!
    Artemus. likes this.
  4. Sidharth.v
    Eclair Mar 6, 2021
    Sidharth.v , via OnePlus 8T , Mar 6, 2021 :
    Yess I faced the same issue and now it is being solved slowly
