Working OnePlus 8T battery via OnePlus 8T Aquamarine Green
  1. H1609444748759 , via OnePlus 8T Aquamarine Green , Jan 4, 2021 :
    I too bought OnePlus 8t on 31st December 2020. When I switched on, os updated immediately. After being used for 4 days. I found that battery get drained very fast. Charging happens very fast, the battery also drain very fast. 100% power goes to 30 % in 5 hours . I need help from any one . I will happy if I get reply from OnePlus customer care. My email id. [email deleted by the moderation team - please avoid sharing private info in a public forum] .
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jan 4, 2021
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jan 4, 2021 :
    Snap some screenshots of these 2 batterystats. Also mention the screen time.
    If you don't see anything obvious you could also investigate stuff further by looking at the actual CPU usage via adb shell.
    CPU usage (adb shell) : top -m 10 (or a other number of your choosing).
    A other useful command enforces the automatic background optimizing normally done when charged to 100% and left connected and not used long enough.
    Background optimizing (adb shell) : cmd package bg-dexopt-job
    Adb installation.
    https://www.xda-developers.com/install-adb-windows-macos-linux/
    youbi likes this.
  3. youbi
    Assistant Head Moderator Assistant Head Moderator Jan 5, 2021
    youbi , Jan 5, 2021 :
    Hi, I've deleted the email you shared here. The truth is that this is a public place and you are mostly talking with fellow users, so private info like emails shouldn't be shared here.
    Hope you understand.
    Has for issue you refer regarding the battery, you mean after 5 hours of actual use with the screen on?
  4. Sidharth.v
    Eclair Jan 7, 2021
    Sidharth.v , via OnePlus 8T , Jan 7, 2021 :
    I also suffer this I bought on December 20 as he said massive battery lose even it is in 60hz and I have limited background process and turned off always on display the battery lose even when in idle
  5. Sidharth.v
    Eclair Jan 7, 2021
  6. Gav_W86
    Moderator Moderator Jan 7, 2021
  7. Sidharth.v
    Eclair Jan 8, 2021
    Sidharth.v , via OnePlus 8T , Jan 8, 2021 :
    Sir I am a very less user donot play games also is use like for 5 to 10 minutes so basically when I calculate I use about 3 to 4 hour and when I go to sleep the charge maybe 60 but when I wake it maybe 50 or 48 like that so I am so sad of this
  8. Gav_W86
    Moderator Moderator Jan 8, 2021
    Gav_W86 , Jan 8, 2021 :
    the first battery screen will show your exact active use time since last full charge. regardless of gaming or not active use will use the battery.
  9. Sidharth.v
    Eclair Jan 9, 2021
    Sidharth.v , via OnePlus 8T , Jan 9, 2021 :
    Yes
  10. Gav_W86
    Moderator Moderator Jan 11, 2021
    Gav_W86 , Jan 11, 2021 :
    so show the power use graph screen and the screen with the active use time if you want us to help
  11. Sidharth.v
    Eclair Jan 12, 2021
    Sidharth.v , via OnePlus 8T , Jan 12, 2021 :
    Power use graph ? Do u mean the graph that is shown in battery usage
  12. Gav_W86
    Moderator Moderator Jan 12, 2021
    Gav_W86 , Jan 12, 2021 :
    yes
    Artemus likes this.
  13. Sidharth.v
    Eclair Jan 14, 2021
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jan 14, 2021
  15. Sidharth.v
    Eclair Jan 14, 2021
    Sidharth.v , via OnePlus 8T , Jan 14, 2021 :
    Yes slightly correct whatsapp is correct because I used to call using whatsapp and if u calculate the usage and minus or the battery really should be more than this u don't know where this test of the percent battery is going
  16. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro , Jan 14, 2021 :
    Personally I think apps like this is more helpful when it comes to monitor battery.
    Also adding some guide that used BetterBatteryStats to view and analyse.
    You can force manual background optimizing and view the actual CPU usage via ADB.
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    Alternate battery stats app.
    https://play.google.com/store/apps/details?id=com.gsamlabs.bbm
    ( https://play.google.com/store/apps/details?id=com.gsamlabs.bbm.pro )
    Adb installation.
  17. Sidharth.v
    Eclair Jan 14, 2021
    Should I install that ADB also
  18. Swejuggalo
  19. Sidharth.v
    Eclair Jan 14, 2021
  20. Swejuggalo
