4
ONEPLUS 8t camera
  1. #21
    P1617783449501 and AK_TECH like this.
  2. deepak2255
    Gingerbread Dec 5, 2020
  3. ritvik007
    Cupcake Dec 11, 2020
    trimmer likes this.
  4. THEONEGOD
    Eclair Dec 15, 2020
    THEONEGOD , via OnePlus 8T , Dec 15, 2020 :
    Under good light the camera is decent, but under any shadow conditions or low light the photo would have a lot more noise. Video wise its worse with more noise and the camera adjusts lighting which make the video shot very inconsistent.
    trimmer likes this.
  5. trimmer
    Froyo Dec 15, 2020
    trimmer , Dec 15, 2020 :
    Update after update after update. So why realise for sale what is wrong? Why that wasn't checked before production start? Because they need money and users to test device then they do few updates and forgets about phone and story will start again with new device. So waiting for update it isn't solution. I already received 3 updates, and every single one fix little something but make other areas even worst. Yes- reported in first month all bugs, issues and problems. Get nothing back at all. OP should change name from never settle to Settle just after you buy device.
  6. #26
  7. MallePranavDheerajYT
    Gingerbread Dec 16, 2020
    MallePranavDheerajYT , Dec 16, 2020 :
    It's look like difference in image processing and actual picture we see it's an software glitch may be it
    The next soft ware update may help to resolve it or
    Try some other camera settings
  8. DarshanMeniya
    OnePlus TV Product Ninja 2021 Dec 16, 2020
  9. SeyedBry
    Eclair Dec 16, 2020
  10. DarshanMeniya
    OnePlus TV Product Ninja 2021 Dec 26, 2020
  11. C1609003903917
    Cupcake Dec 29, 2020
  12. LordPM
    Gingerbread Dec 29, 2020
    LordPM , via OnePlus 8T , Dec 29, 2020 :
    Did you have yellow lighting in background.
    Coz 8t struggles with yellow color in low lighting.
    To resolve this go to manual(pro) mode. And set the white balance to your desire.
    Currently the normal(photo) mode is not optimized.
    But it's always good to get your skills up in pro mode.
    For the color shift, I this its changing the wb to show you better result. It not perfect yet.
  13. Rhythmchugwani
    Eclair Dec 29, 2020
    Rhythmchugwani , via OnePlus 8T , Dec 29, 2020 :
    I do use it bro.
    I am a photographer.
  14. LordPM
    Gingerbread Dec 30, 2020
    LordPM , via OnePlus 8T , Dec 30, 2020 :
    That's cool.
    I get it what you are trying to say.
    Image one has warmer tones compared to neutral ones on the second.
    In pro mode, check if it is consistent or not, between two photos.
    If so then manual mode, needs software updates.
    Rhythmchugwani likes this.
  15. #35
    LordPM likes this.
  16. Rhythmchugwani
    Eclair Dec 31, 2020
    Rhythmchugwani , via OnePlus 8T , Dec 31, 2020 :
    Bro this is happening only if you click a picture on 2x zoom.
    And pro mode doesn't supports zoom, so its gonna be same in pro mode.
    And the camera app definately needs a software upgrade.
    LordPM likes this.
  17. PritishPriyam
    Ice Cream Sandwich Dec 31, 2020
  18. #38
