2
OnePlus 8T hang issue!
  1. eastbay
    KitKat Feb 1, 2021
    eastbay , via OnePlus 8T T-Mobile , Feb 1, 2021 :
    I had to do a factory hard restart which is erasing everything. Lot's of work. But everything came back as normal. Thanks 👍🏻 This might Have to do with your provider. there server might be overloaded! or did you reset your WiFi, password, and you must Try to unplug modem and router. then plug in reboot them! then let me know please
    #41
    BIPIN V RAJ likes this.
  2. eastbay
    KitKat Feb 1, 2021
    How Are you making out with that issue. I'm not blowing this off 📴
    #42
  3. eastbay
    KitKat Feb 3, 2021
    #43
  4. Meeblaze388
    Cupcake Feb 17, 2021
    Meeblaze388 , via OnePlus 8T , Feb 17, 2021 :
    I'm facing this issue from week with the latest 11.7 update..... Device randomly hangs and stucks.... OnePlus is a community brand ..... But this is a bad thing .... The moving with its top of the line specs should not face this issue..... What is the problem here???
    #44
  5. vikarshaikh18
    Gingerbread Feb 17, 2021
  6. Neel Maitra
    Cupcake Feb 18, 2021
    Neel Maitra , via OnePlus 8T , Feb 18, 2021 :
    I'm facing the same. My phone freezes whenever I use the alarm app. The alarm rings but the phones display is totally blank. I have to dismiss the alarm from the notification bar. After that the phone doesn't respond properly at all. Notification bar doesn't slide down, app drawer doesn't open etc.
    #46
  7. psygarden , via OnePlus 8T Aquamarine Green , Feb 18, 2021 :
    Try to Reset the Phone. Make sure to backup your data first.
    #47
    B1615349511256 likes this.
  8. B1615349511256
    Cupcake Mar 18, 2021
    #48
  9. Gor.V
    Ice Cream Sandwich Mar 20, 2021
    Gor.V , Mar 20, 2021 :
    Hi, try to clear cache, unwanted apps (flagged harmful by google play protect) and try to reduce storage usage to not more than half to ensure optimal performance. May not work for all.
    #49
