Network/Connectivity OnePlus 8T not connecting to 5G
  1. frasharp
    Cupcake Oct 25, 2021
    frasharp , Oct 25, 2021 :
    my OnePlus isn't connecting to 5G (mobile network) eventho my data plan is 5G and my phone supports 5G.
    I have a OnePlus 8T (KB2003) EU variant.
    Here are some questions and answers to avoid unuseful comments.
    Q) Did you try to reset network settings?
    A) Yes.
    Q) Did you try to perform a factory reset?
    A) Yes.
    Q) Did you try to perform a full reset through MSM tools?
    A) Yes.
    Q) Did you try to force NR only through phone settings (*#*#4636#*#*)?
    A) Yes.
    Q) Did you set preferred network to 5G in network settings?
    A) Yes.
    Q) Did you update firmware to latest version?
    A) Yes.
    Q) Is your phone rooted?
    A) No.
    Q) Did you try to reboot phone?
    A) Yes.
    Q) Did you try to put SIM card in another 5G phone?
    A) Yes, I tried in a Samsung Galaxy S21 5G, and 5G was working.
  2. BetaBot
    Jelly Bean Oct 25, 2021
    frasharp and Caomhin like this.
  3. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Oct 25, 2021
    Caomhin likes this.
  4. G_plusone
    Nougat Oct 25, 2021
    G_plusone , Oct 25, 2021 :
    who's your network provider?
    did you contact them?
  5. puccellino
    Lollipop Oct 25, 2021
    puccellino , Oct 25, 2021 :
    Your phone also has to be on the carrier list of 5 G supported phones. Ie your specific model.
    frasharp likes this.
  6. tutskie , via OnePlus 8T Aquamarine Green , Oct 31, 2021 :
    1. Check your country's available 5g bands,
    2. If your OP 8t is kb2003, check weather the update build number for the latest update is 11.0.11.11KB05BA, If it's 11.0.11.11KB05AA you got the NA version which i believe there's no n78 5g band.
  7. shibin.ts
    Cupcake Nov 12, 2021
    shibin.ts , via OnePlus 8T , Nov 12, 2021 :
    Hi, I'm also facing the same issue. Mine is KB05AA. How to change to KB05BA?
