11
Network/Connectivity OnePlus 8T randomly losing signal/network/4g/5g
  1. Frank!!
    Cupcake Jan 20, 2021
    Frank!! , Jan 20, 2021 :
    I have exactly the same problem with educom in austria. Only a reboot helps to be able to make/receive calls. The signal gets lost after some time and nobody can call me. The phone is not usable like this.
    #61
    Thomas_01011111 and BenschiBox like this.
  2. Q1610018273062
    Cupcake Jan 26, 2021
    Q1610018273062 , Jan 26, 2021 :
    INTENTE TODO YA Y ES COSA DEL TELEFONO MENUDA ESTAFA DE TERMINAL ..... y lo mas importante no lo solucionan te dicen resetea el terminal y ya esta como si fuera tan secillo con el peligro de perdida de datos que tiene eso me siento estafado
    #62
  3. rogacp
    Cupcake Jan 27, 2021
    rogacp , Jan 27, 2021 :
    Hello community,
    I am new to the OnePlus. Bougt 8T in early January.
    I am also noticing network problems. Have arranged for SIM card to be replaced, but reading this thread this will not solve anything.
    I am using bob in Slovenia - already seen a couple of other users with the same problem.
    Is OnePlus working on solving this issue? If not I will return the phone.
    Best Regards!
    #63
  4. eastbay
    KitKat Jan 30, 2021
    eastbay , via OnePlus 8T T-Mobile , Jan 30, 2021 :
    I have full signal strength, and 5g service out in front of my home. When I go inside. I have no 5g. I called support, and they told me 5g can't penetrate my home because it's older. And the building materials are old and it can't penetrate older
    Home. But 4g is still strong enough . So just leave it alone. Or move to new home.
    #64
  5. T1606139447767
    Cupcake Feb 6, 2021
    T1606139447767 , Feb 6, 2021 :
    I have the same problem. Dual SIM (Telenor+Tele2), with data on SIM 2. Occasionally mobile data stops working, and I have to toggle airplane mode to get it working again. All the carriers here in Sweden support band 20, so there is no avoiding that.
    #65
  6. DIVITH.C , via OnePlus 8T Aquamarine Green , Feb 6, 2021 :
    Please update on what service provider you are using. Incase JIO. Open my jio app and type slow speed in the LiveChat in JioCare Help and Support tab or HelloJio
    1612609398587.jpg said:
    Then jio assistant will run a full diagnostic for your jio sim.
    Let me know if this helps in diagnosis.
    #66
  7. phemt
    Ice Cream Sandwich Feb 6, 2021
    phemt , via OnePlus 8T Aquamarine Green , Feb 6, 2021 :
    It's all related network bands; lte 20 (800mhrz) is more unstable than 1600 mhrz one. You have to check what band your carrier dealer uses in your area and if your area is more or less populated.
    #67
  8. boko34
    Froyo Feb 6, 2021
    boko34 , via OnePlus 8T , Feb 6, 2021 :
    That is not an exuse. I'm was using this same sim with Nokia, Samsung, Huawei and Xiaomi. All worked with no problems. Only Oneplus has this problem with losing signal. If they cannot fix this is better to stop selling phones. 800hz,1600hz... doesn't matter. The phone must work.
    #68
    chingfu and Kuglitsch like this.
  9. Kuglitsch
    Cupcake Feb 6, 2021
    Kuglitsch , Feb 6, 2021 :
    Same issue here in Austria with A1 (provider) my and i totally agree with the person above me, this phone is not usable with the current software Problems and the connectivity issues.
    Dont get me Wrong i had the best experience in my life with my old 5T but the 8T is just REEEEALLY NOT GOOOOD
    #69
    chingfu likes this.
  10. HofaTheRipper
    Cupcake Feb 24, 2021
    HofaTheRipper , Feb 24, 2021 :
    Hi, i had the same problem with my 8T Austria A1 :
    At different locations i had LTE connection but if someone tried to call me, the connection dropped to 3G with roaming.
    Excluding Band 20 didnt solve my problem but excluding CDMA Band 1 (2100 MHz) did it for now! I could also reproduce it if i reactivate this Band 1 or exclude it.
    The strange thing:
    CDMA Band 1 on: On Calls, Phone sets signal to 3G roaming on Band 1 (2100 MHz)..... Calls dont work.
    CDMA Band 1 off: On Calls, Phone sets signal to 3G without roaming also on 2100MHz (which should be Band 1.... everything working fine now.
    Hopefully someone from OP reads this and can fix this in an future update.
    #70
    chingfu likes this.
  11. Kuglitsch
    Cupcake Feb 25, 2021
    Kuglitsch , Feb 25, 2021 :
    ok i just made the latest update and guess what, they didnt do anything to handle this problem.
    i tried talking with my provider and so on but they cant do anything if the phone doesnt work
    For testing i tried to do a simple speedtest with different apps and websites. The Norm for my contract would be 16 to 20 Mbps, i think.
    the phone can hold the connection for about 3 sec. after that the downloadrate dropps down to 0,1 Mbps and then the connection is lost. And for upload there isnt even a connection to measure something .
    So dear dev Team or whatever geniuse is currently managing the support for this phone get your thing together and fix this.
    Until then i will do everything in my might to stop people to buy this phone.
    PS: i still think the onplus 5t was the best phone ever but yeah...
    #71
    chingfu likes this.
  12. chingfu
    chingfu , Feb 25, 2021 :
    How did you actually do this?
    Nevertheless I actually have the same problem that's been discussed here in lengths! Tried A1, BOB, Magenta, HoT and now EDUCOM... obviously the phone's broken (software!?) and it's fascinating nobody is going to fix this. There are numerous threads pointing out the same hard-/software bug...
    https://forums.oneplus.com/threads/verliert-empfang.1341287/
    https://forums.oneplus.com/threads/oneplus-8t-empfangs-probleme.1345631/
    https://forums.oneplus.com/threads/8t-verbindungsprobleme.1357626/
    https://forums.oneplus.com/threads/...st-used-it-for-2-days-since-purchase.1389764/
    just to name a few.
    Dear OnePlus could you PLEASE fix this! Right now my €600,- phone is nothing more than dead weight, and I can't even sell it used in good conscience, because chances are high it's not working for the buyer too.
    #72
  13. HofaTheRipper
    Cupcake Feb 26, 2021
    HofaTheRipper , Feb 26, 2021 :
    With the app QuickShortcutMaker. Here is a video (it was Band 1 CDMA 2100) Didnt have problems since i changed this:
    #73
    Kuglitsch likes this.
  14. shahi14323
    Ice Cream Sandwich Feb 26, 2021
    #74
  15. #75
  16. eastbay
    KitKat Feb 26, 2021
    eastbay , via OnePlus 8T T-Mobile , Feb 26, 2021 :
    I would assume after reading all colegues. Notes. You have a connectivity problem. Your modem Is weak not getting signal from outside. Clear cache, reset phone. Then call provider or oneplus technical support. Your not getting proper decibel count to your phone.
    #76
  17. eastbay
    KitKat Feb 28, 2021
    #77
  18. boko34
    Froyo Mar 5, 2021 at 10:16 AM
    boko34 , via OnePlus 8T , Mar 5, 2021 at 10:16 AM :
    Ok, here is the thing...
    I have the same problem from day one on all stable version of the OS. Tried everything:
    1. Reset network
    2. Reset the phone ( factory reset )
    3. Modified APN settings
    4. Call my provider ( from there site everything is OK )
    5. Changed 3 sim cards
    6. Tried with different providers ( I'm using A1/bob ) Telekom, Hot, Telemach
    The problem is still here, so I decided to work with them and now I'm in beta OS. Every single update have the same problem and all the logs we sent to them... They still can't fix the problem. Don't know what to do. Very, very disappointed.
    #78
    chingfu likes this.
  19. B1611071134748
    Cupcake Mar 6, 2021 at 10:33 PM
    B1611071134748 , Mar 6, 2021 at 10:33 PM :
    This has been an issue with the phone for nearly a year and NO word from Oneplus, NO updates, NO support. Only Oneplus fans saying updates "will fix the issue" when I can confirm that the NEWEST oxygen updates did nothing? It's a really basic thing a top-end smartphone should be able to do; keep itself connected to the mobile network provided, and RECONNECT AUTOMATICALLY WITHOUT NEEDING A HARDWARE RESTART EVERY FEW MINUTES. I've missed multiple important calls and emails thanks to this already. It's a waste of my time and surely should be acknowledged?
    Also the replies from these so called "community helpers" are nothing but condescending and ignorant of the issue. The 8T and other models are buggy/incorrectly configered for 4G/5G connectivity and will constantly disconnect from the mobile carrier permanently until reset via a restart. This is NOT A USER FAULT. Anyone saying otherwise need to take a moment to stop blaming US for expecting a £500+ product for not fulfilling a basic advertised feature.
    #79
    chingfu likes this.
  20. B1611071134748
    Cupcake Mar 6, 2021 at 10:37 PM
    B1611071134748 , Mar 6, 2021 at 10:37 PM :
    If you're going to be condescending to an issue Oneplus is being ignorant of, when clearly everyone is following these suggestings and not getting anything solved. Please don't reply to other threads on this site. It's not helpful to see people suggesting that the user is at fault for what is clearly a widely documented hardware/software fault at Oneplus.
    #80
    chingfu and northbay5566 like this.
