4
OxygenOS OnePlus 8T - System UI Not Responding via OnePlus 8T
  1. Afz@1001
    Eclair Dec 9, 2020
  2. U1602757492730
    Cupcake Dec 14, 2020
    U1602757492730 , via OnePlus 8T , Dec 14, 2020 :
    Same here it's says system ui isn't responding and it's happening frequently while using apps like insta. I have upadated my Instagram but was not of any help.
    Afz@1001 likes this.
  3. Liehjan
    Marshmallow Dec 14, 2020
    Liehjan , Dec 14, 2020 :
    If system UI don't respond I would do a factory reset if next update won't fix the issue...
  4. Afz@1001
    Eclair Dec 14, 2020
    Afz@1001 , via OnePlus 8T , Dec 14, 2020 :
    I think 10 or more times did that. It's very bad from oneplus lot of bugs
  5. Afz@1001
    Eclair Dec 14, 2020
    Same problem bro.. A lot of bugs in the one plus 8t
  6. Liehjan
    You already did 10 factory resets?:eek: I would contact support and get your device replaced.
  7. Afz@1001
    Eclair Dec 14, 2020
    Replace not possible.. Because very bad service experience from the Kerala one plus service centers
  8. Liehjan
    Don't take it through a service center, contact oneplus support online instead... You may get more lucky that way
  9. Afz@1001
    Eclair Dec 14, 2020
    No use.. Already send mails the same reply restore and factory rest. it's my bad luck that brought oneplus
  10. Liehjan
    You could try one thing, join the beta program when beta starts...Other than that I'm out of ideas what to do :(
  11. Afz@1001
    Eclair Dec 14, 2020
    Ok
  12. X1607677713329
    Cupcake Dec 18, 2020
  13. OALEXANDER
    Nougat Assistant Head Moderator Dec 18, 2020
    OALEXANDER , Dec 18, 2020 :
    The service center guys in Kochi should flash your phone, I had been there once and got it fixed for my OP5 , if you are in the same city.
    Meanwhile have you tried submitting a feedback here
    https://forums.oneplus.com/feedback
  14. P_Suja
    Eclair Dec 19, 2020
    P_Suja , Dec 19, 2020 :
    Preferably factory reset or wait for any updates or finally gonto oneplus service center
  15. #16
  16. KhanAamer
    Ice Cream Sandwich Dec 19, 2020
  17. #18
  18. jeetulalwani1211
    Cupcake Dec 22, 2020
    jeetulalwani1211 , via OnePlus 8T , Dec 22, 2020 :
    Is this why I paid so much money for an 8T to get stuck in emergencies? Screen freezes suddenly and touch doesn't work for a minute or two before I get a pop up saying that system ui not responding. How can this occur in a new phone with latest chipset and latest Android version?
  19. StefanStark
    Ice Cream Sandwich Dec 23, 2020
    StefanStark , via OnePlus 8T Aquamarine Green , Dec 23, 2020 :
    Because this is newest Android version a lot of apps are not fully optimise and this may cause issues.
    Your error description is not providing any useful informations.
    When does this happen?
    Any specific app in use that may cause this?
    Have you tried restart the phone?
    Are you on latest oxygen version?
    Are all playstore apps on the newest version?
    Are you using sideload apk or only playstore?
    Standard launcher or any alternative one?
    If no info provided or just so less you did - easiest answer to give support is always...
    DO FACTORY RESET - prior to this backup your data.
    Install apps one by one and see if problem reappears.
