OnePlus 8T tap vibration via OnePlus 8T
  1. I1634430882559
    Cupcake Oct 23, 2021
    I1634430882559 , via OnePlus 8T , Oct 23, 2021 :
    So even though this is a introduce yourself thread ( I am new and I can't make other categories of threads) I moved from a one plus 8 to an 8t. On my one plus 8 it vibrates everytime I press to open an app let's say I want to open chrome I tap chrome it vibrates when I click and opens. I loved that but it doesn't do that on my 8T which is strange I am beginning to think that it was a defect but I am not sure. Because my keyboard vibrates normally and my phone vibrates with gestures which means the motor is workin. Can someone tell me if this is a defect or it just isn't a feature on the 8T
    edit: can one try if they have both phones. try opening an app or like an Instagram post does it vibrate on your 8 and not on your 8T. thank you for your help
    puccellino likes this.
  2. pablofg1978
    Head Moderator Head Moderator Oct 23, 2021
    pablofg1978 , Oct 23, 2021 :
    Hello there,
    I moved your thread to a more appropriate section. Like you mentioned, introduce yourself section is not meant for this type of content.
    Please check this thread
    https://forums.oneplus.com/threads/...red-faster-introducing-starting-point.812193/
    puccellino, Mr. BG and G_plusone like this.
  3. puccellino
    Lollipop Oct 23, 2021
    puccellino , Oct 23, 2021 :
    Are your haptic feedback settings the same on each phone?
    Gor., I1634430882559 and G_plusone like this.
  4. G_plusone
    Nougat Oct 23, 2021
    G_plusone , Oct 23, 2021 :
    possibly such a feature was changed in the 8T the vibration settings maybe different as mentioned above
    Gor. and I1634430882559 like this.
  5. I1634430882559
  6. I1634430882559
  7. puccellino
    Ok, I'm not a fan of vibrations when tapping. When I got my 8T, I spent ages turning it off. I'd have a play in the setting area. There are many different places you can set vibrations and haptic vibrations on. It possibly had changed as @G_plusone mentioned. Look on the Google keyboard settings as well.
    Good luck.
  8. I1634430882559
    Thank you so much for your help
