2
Oneplus 9 and 9 pro refresh rate via OnePlus 9
  1. zeeshannassar
    Cupcake Apr 28, 2021
    zeeshannassar , via OnePlus 9 , Apr 28, 2021 :
    Oneplus 9 and 9 pro refresh rate at 120 hz is causing WhatsApp content scrolling bad impact.
    Refresh rate drops as part of oneplus' dynamic changing rate feature but its not re-adjusting enough for WhatsApp scrolling
    Causing eyes to suffer
    When you scroll vigorously up down then only it adjusts somewhat
    Plz report this
    praasjain and X1539772741950 like this.
  2. Shailender Sharma
    Nougat Apr 28, 2021
    KluGe, the_o2, Caoimhín and 2 others like this.
  3. Tokolozi
    Most Original Avatar Apr 28, 2021
    Kruemelfelix, KluGe, the_o2 and 2 others like this.
  4. calvin35 , via OnePlus 7 Pro T-Mobile , Apr 30, 2021 :
    This is NOT a problem with WhatsApp, this is a not so we'll known problem with the 9 Pro. In-app scrolling is not up to par on this phone. YouTube is another app that suffers from the same scrolling problem that does not happen on any other phone. The S21 Ultra does not have these same scrolling problems. Hopefully OnePlus will do fix it soon.
    X1539772741950 likes this.
  5. #5
    J1615493696774 likes this.
  6. X1539772741950 , via OnePlus 9 Pro , May 4, 2021 :
    Even I have faced this problem severely. The same issue is there with a few other apps also. I think it's the device software issue. I request OnePlus to roll out an efficient update ASAP.
    I love The scrolling on apps like facebook and Instagram and I expect the same to be with Whatsapp and others apps as well.
    calvin35 likes this.
  7. X1539772741950 , via OnePlus 9 Pro , May 4, 2021 :
    Scrolling on YouTube happens at 60 hz on the 9 Pro. Hope OnePlus resolves the issue ASAP.
  8. praasjain
    Donut May 10, 2021
    praasjain , via OnePlus 9 Pro , May 10, 2021 :
    I am also facing same problem in oneplus 9pro
    My most of time is used in whatsapp & for amooth functioning, i bought oneplus 9pro high end smartphone.
    But what's the use if we face such problems.
    My staff has normal 200 usd oppo phone, & his WhatsApp running smoother than mine.
    I also switched to 60hz refresh rate, but in vain.
  9. calvin35 , via OnePlus 7 Pro T-Mobile , May 11, 2021 :
    It actually looks more like 30-40Hz. Even 60Hz looks better than what I experienced.
  10. SyamKG
    Ice Cream Sandwich May 11, 2021
    SyamKG , via OnePlus 8T , May 11, 2021 :
    Oh boy!.. we can force 120hz using adb command. If whatsapp doesn't support it, then also it should run in 60 right??? It's definitely a oos issue I think..
  11. Tokolozi
    Most Original Avatar May 11, 2021
    Tokolozi , May 11, 2021 :
    You can always force something. If WhatsApp devs enabled it by default, you wouldn't need to force it.
    Caoimhín likes this.
  12. SyamKG
    Maybe. I think it's an Oxygen OS feature. I'd X2 pro before..and it had 90hz on whatsapp.
  13. LeonelAioria
    Froyo Jun 30, 2021
    LeonelAioria , Jun 30, 2021 :
    I'm having the same issue, happens with Whatsapp, Youtube, google shelf, google photos and i'm pretty sure other apps have the same issue... will try forcing 120hz to see if the issue is resolved, but i'm pretty disappointed on this one... This is not a cheap phone, as users we expect the best of the experiences at this price tag. One Plus 9 Pro user here.
  14. LeonelAioria
    Froyo Jun 30, 2021
    LeonelAioria , via OnePlus 9 Pro , Jun 30, 2021 :
    Update, forced refresh rate to 120hz via adb... Issue persists, raised a bug report, let's see how it goes
