8
OnePlus 9 and 9PRO/ GMAIL notification fixing-for everyone via OnePlus 9 Pro
  1. stajni13
    Gingerbread Sep 11, 2021
  2. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Sep 11, 2021
    Nipu_1998 , Sep 11, 2021 :
    Thank you. Really appreciate this. Will direct other users who are facing the issue to this thread.
  3. Nipu_1998
  4. the_o2
    OnePlus 9 Series Expert Community Expert Sep 11, 2021
  5. stajni13
    stajni13 , via OnePlus 9 Pro , Sep 11, 2021 :
    Yes, share this to all user's...
    Helder_DAlmeida, Dresa91 and Caomhin like this.
  6. Caomhin
    Caomhin , via OnePlus 9 Pro , Sep 11, 2021 :
    Thanks for the tag on this
    Currently my Gmail Notifications work as is. But if they do stop working again I will utilise the info you have given and will in the meantime advise others to try it and see if it can help.
    Nice find @stajni13
  7. Caomhin
  8. Aaron2017
    Lollipop Sep 11, 2021
    Aaron2017 , Sep 11, 2021 :
    Thanks for the tag.👍 I already saved it and shared it with another user. Btw @Bobbie63 tag didn't take, i'm hoping this one does as he is proven to be impossible to tag.
  9. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Sep 11, 2021
    Helder_DAlmeida and Caomhin like this.
  10. Caomhin
    @Bobbie63 did say recently in another post that his tag is not working for some reason. It could be down to a space or something.
  11. Aaron2017
    Indeed, putting a space behind @Bobbie63 seems to do the trick.
    Helder_DAlmeida, Caomhin and Dresa91 like this.
  12. Helder_DAlmeida
    Marshmallow Sep 11, 2021
  13. Bobbie63
    Bobbie63 , Sep 11, 2021 :
    It is. It's the mysterious OnePlus space monster
    It's get added as a bonus for good behavior.
  14. Caomhin
    You got rewarded with a space, soon you will have a full stop as well. 😜🤣
    Dresa91, Bobbie63 , HarshKK14 and 2 others like this.
  15. _MarcoJ
    Froyo Sep 12, 2021
    _MarcoJ , Sep 12, 2021 :
    No luck for me. Does it work for you guys?
    I think it's a sync issue, not a notification issue, because I can only get new mails by opening Gmail app to trigger a sync.
  16. A1594910915738
    Gingerbread Sep 12, 2021
    A1594910915738 , Sep 12, 2021 :
    I did the change on my OnePlus 6T, at the moment, it's still working now...
    BUT it always works for a few hours after a reboot, so still to early to say... Let's hope though
  17. A1594910915738
    No, it doesn't work, it works after a reboot, but after a few hours it stops again synching... Too bad, really hoped that this was the fix :-(
  18. G_Devang_Shah_YYYJ
    Cupcake Sep 14, 2021
  19. Gav_W86
    Moderator Moderator Sep 14, 2021
    Caomhin likes this.
