Oneplus 9 Battery backup via OnePlus 9
  1. MakB
    Honeycomb Apr 20, 2021
    the_o2 likes this.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Apr 20, 2021
    Dresa91 , Apr 20, 2021 :
    It it good:).
    can you please share the usage stats?:)
    the_o2 and MakB like this.
  3. MakB
    Dresa91 likes this.
  4. Dresa91
    MakB likes this.
  5. MakB
    Dresa91 likes this.
  6. MakB
    Dresa91 likes this.
  7. Dresa91
    MakB likes this.
  8. ajit.sandhu
    Gingerbread Apr 21, 2021
    ajit.sandhu , via OnePlus 9 , Apr 21, 2021 :
    When i bought the phone i was getting 5 or 6hr max but after two updates it's improved significantly. current launcher is nova (prime). The only optimization app i use is greenify (with system app).
  9. MakB
    Honeycomb Apr 21, 2021
    MakB , via OnePlus 9 , Apr 21, 2021 :
    Pl share your charging pattern
  10. ajit.sandhu
  11. the_o2
    OnePlus 9 Series Expert Community Expert Apr 21, 2021
    the_o2 , Apr 21, 2021 :
    If you keep watching YouTube or other streaming apps with stable connection you will get better SOT.
    As I can see you are not using any social media apps so there is no background drain, no PUBG or COD :p and if you keep using the phone there will be no idle drain as well ;)
    GPS and bad mobile network are the real culprit of battery drain.
    I have a screenshot of 6hrs+ SOT of my OP5 after 3 year without any battery replacement :sweatsmile:
    But indeed you got a very good device :cool:
    Caoimhín, Dresa91 and MakB like this.
  12. MakB
    Hahhaa.... Thanks buddy
    the_o2 and Dresa91 like this.
