OnePlus 9 Pro 11.2.4.4 Review via OnePlus 9 Pro
  1. PKkeys
    Donut Apr 19, 2021
    PKkeys , via OnePlus 9 Pro , Apr 19, 2021 :
    Okay, Whatever the thing listed as update, They are not achieved or updated.
    1. Still Keyboard Lag on Certain apps like KITE, EDGE, Etc.
    2. Battery health still displayed as "Over heat" in all info apps
    3. Still facing white balance issues on videos
    Good news -
    They fixed sharpness level on the camera images
    snke likes this.
  2. Tokolozi
    Most Original Avatar Apr 19, 2021
    Tokolozi , Apr 19, 2021 :
    For 2 especially I think these apps will need to be updated.
    Not that I see any benefit over using these apps instead of the built in diagnostic tools.
  3. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 19, 2021
    Caoimhín , via OnePlus 6T , Apr 19, 2021 :
    1. Clear Gboard Keyboard App info Cache
    2. Go through 2 full charge cycles restart the phone after the 2nd full charge cycle and see if Overheat is still an issue. Also check Thermals with CPU-Z or similar to see what it shows for temps.
    3. Clear the Camera App info Cache and App info Storage as well. Restart the phone. Then take pictures in different lighting and image scenarios to see how they look compared to previous pictures taken.
    Let us know in a couple of days how this works out for you.
  4. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 19, 2021 :
    2. It's a well known issue at least. But it may also be caused at a lower system level that may be more time consuming to solve that what was possible to do for this build. Without really knowing and just guessing this could be triggered by something on the SoC driver level.
    I haven't read anything about other devices SD888 experiences yet.
    If I understood it correctly the problem came with 11.2.2.2 or did it exist even before that? Seen some hints of that...
    This new build is dated 12 April and code frozen at an unknown date before that. What was possible to add in this update had to be done in good time before code freeze and internal testing.
    Caoimhín likes this.
  5. MarkoBatrac
    Ice Cream Sandwich Apr 19, 2021
  6. PKkeys
    Donut Apr 20, 2021
    PKkeys , via OnePlus 9 Pro , Apr 20, 2021 :
    Update :
    1. After cleaning all DATA and CACHE to your GBOARD, doesn't do anything. It's confirmed in XDA forums that REFRESH RATE is causing issue for this. So awaiting an update
    2. Overheating stopped after 2 charge cycles. Temp ranges from 29-33 on normal usage and 36-39 on charging.
    3. Video level still seemed to be missing the white balance level after 10-15 video camera tests. Hoping to be fixed in another update.
    Swejuggalo and Caoimhín like this.
  7. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 20, 2021
    Caoimhín , via OnePlus 6T , Apr 20, 2021 :
    Please send Bug reports and give Feedback on the outstanding issues back to the OnePlus OOS developers. So that they can investigate them. Thank you.
    Community App Feedback tool
    You can also contact bughunters@oneplus.com
    PKkeys likes this.
  8. PKkeys
    Donut Apr 20, 2021
