OnePlus 9 Pro 5G Battery Discharge Issue via OnePlus 9 Pro
  1. Harshit_Rajput , via OnePlus 9 Pro , Jan 14, 2022 :
    Somehow the battery discharges too fast on oneplus 9 pro 5G. I have disabled ambient display, enabled lock screen after 30 s, disabled ram optimization, enabled optimise for most of the apps, i only use whatsapp and insta
    and still even if i turn on Battery Saver yet, my phone doesn't work for 24 hrs after full charge.
    i have even set refresh rate to 60hz. :( what more can i do?
    I know it depends on the usage. But it should at least sustain for 24 hrs (atleast in battery saver mode). I used OnePlus 5 before this and it used to run for more 24 hrs. (best phone ever)
    Am i doing something wrong or missing something ?
    Is this expected in any way? Can i do something differently?
  2. Trita11
    Froyo Jan 14, 2022
    Laxman9999 and Harshit_Rajput like this.
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jan 14, 2022
    Tokolozi likes this.
  4. #4
  5. Harshit_Rajput , via OnePlus 9 Pro , Jan 14, 2022 :
    why did i buy this :(
    imagine buying a new flagship phone and using it on battery saver
    subsidiary likes this.
  6. Trita11
    Froyo Jan 14, 2022
  7. Trita11
    Froyo Jan 14, 2022
  8. Trita11
    Froyo Jan 14, 2022
  9. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro , Jan 14, 2022 :
    I've peaked at 11h SOT... and with my usage I can say it's not worse than my previous Oneplus (7 Pro/8 Pro).
    Don't really know what happens on your device. Without knowing how you use WhatsApp and Instagram it's hard to know if that drain is realistic or caused of some issue.
  10. Harshit_Rajput , via OnePlus 9 Pro , Jan 14, 2022 :
    well you can see the usage as 29 and 17 percent around.
    with other apps using some percent like launcher, tinder, etc
    so you are saying this battery behaviour is expected ? (As per your experience)
  11. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Jan 14, 2022 :
    I'm not a heavy user of any of those apps. But I see plenty of users with massive WhatsApp drain. And some Instagram complaints.
    I have both those apps on my main device for testing reasons. But I don't use them on daily basis.
    My main device on C38. Some days mostly just being there in pocket.
    My second device on C40 NA is more of a test device and most often the one that is used the most due to testing the newest 12 build.
  12. Harshit_Rajput , via OnePlus 9 Pro , Jan 17, 2022 :
    man really not sure how your device get through for more than 24 hours without charging. i just use 3 apps moderately i would say. and i need to charge 1-2 times.
    you are lucky, and/or either I got a faulty device.
    or op9 pro is really lacking in battery. Because I am still a fan of OP5 (used for 4.5yrs), but this one is a disaster.
  13. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jan 17, 2022
    Swejuggalo , via OnePlus 9 Pro , Jan 17, 2022 :
    The apps you use is a highly important factor. Also whatever else that is installed and what those things can do in the background.
    WhatsApp for examples have been pretty terrible for some, even if not using it much. I have it installed on my main device but I barely ever use it nor have much else there than my wife for testing reasons.
    Drain can be pretty complicated.
    I tried to explain some of that in my guide. There are some interesting sources of info in there.
    https://forums.oneplus.com/threads/battery-analysis-and-battery-drain-trouble-solving.1413430/
  14. Harshit_Rajput , via OnePlus 9 Pro , Jan 17, 2022 :
    thanks man. will sure give it a read.
