2
OnePlus 9 Pro - Battery issue
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 3, 2021
    sickchild and C1517144961638 like this.
  2. C1517144961638 , via OnePlus 9 Pro , Aug 3, 2021 :
    So how much SOT are you getting in yours??
  3. #23
  4. #24
  5. Pattabhi29 , via OnePlus 9 Pro Pine Green , Aug 3, 2021 :
    Try turning off Google assistant and all the notifications except the ones you really need, like office wrk related.
    Let's see if tht wrks for you.
  6. #26
    dom_k likes this.
  7. Pattabhi29 , via OnePlus Community App , Aug 4, 2021 :
    It amazes me how PPL get 10 hrs of SOT with 9 pro. You use it at 120 refresh rate ?
    Can you please share an insight to on how it is possible for you? You should be doing something which we are not.
    Also, when you started using 9 Pro did you clone it with old mobile or just a Google cloud login?
  8. C1517144961638 , via OnePlus 9 Pro , Aug 4, 2021 :
    Seriously??? Are you using the device with motion graphics and ultra high video resolution switched ON?? Also I'm facing kinda a display color issue when I watch Netflix in PIP mode do you face it??
  9. #29
  10. Helder_DAlmeida
    Marshmallow Aug 4, 2021
    Helder_DAlmeida , via OnePlus 9 Pro , Aug 4, 2021 :
    I'm not having that issue fortunately.
    The battery for me doesn't last all day but I have AOD, QHD+, 120hz etc.
    sickchild likes this.
  11. sickchild , via OnePlus 9 Pro co-developed with Hasselblad , Aug 5, 2021 :
    Yes i use 120hz, aod, qhd+, enable motion graphics and ultra res. I do migrate all data too. Honestly, i don't know how it works, but i do calibrate battery pack, drain fully and then recharge until 99% everytime i got a new device. Same as i did to all my old 1+ devices
    And my pip mode on netflix player works fine.
    Helder_DAlmeida likes this.
