OnePlus 9 pro bluetooth connectivity via OnePlus 9 Pro co-developed with Hasselblad
  1. #1
  2. hbk1402
    KitKat Sep 28, 2021
    hbk1402 , Sep 28, 2021 :
    Can you check if media output is selected as your sony speaker?
    Follow below steps,
    1. Press volume up or down and click on Media Output (screenshot attached).
    2. Ensure your sony speaker is selected (screenshot attached).
    Test playing the music.
    If the issue still persists, try clearing the cache and data for bluetooth under settings. You need to pair the bluetooth devices again.
    dnoel143 and Caomhin like this.
  3. #3
  4. #4
  5. hbk1402
    KitKat Sep 28, 2021
    Open phone settings and search for bluetooth and select the one as bluetooth app info application (screenshot attached). Then click on storage and cache. Then clear cache and data seperately. Then restart your phone and pair the device again. Play the music and check, ensure the media output is rightly set.
    Caomhin likes this.
  6. #6
  7. hbk1402
    KitKat Sep 29, 2021
  8. hbk1402
    KitKat Sep 29, 2021
    hbk1402 , Sep 29, 2021 :
    Attaching a screenshot for reset option for reference, search reset options under your phone settings, click on it and then perform the reset. After reset, restart your phone, enable bluetooth and connect to your speakers.
  9. #9
  10. hbk1402
    KitKat Sep 29, 2021
    dnoel143 likes this.
