OnePlus 9 pro facing what's app call receiving problem via OnePlus 9 Pro
  1. Padma.J
    Eclair Nov 17, 2021
    Padma.J , via OnePlus 9 Pro , Nov 17, 2021 :
    I pre-booked onePlus nord so exited to use the phone but faced what's app call receiving problem .so shifted to OnePlus 9 pro bought the phone 2 days back facing same problem like nord what to do.I have to go for service center ?
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Nov 17, 2021
    Dresa91 , Nov 17, 2021 :
    What issue are you exactly facing?
    Can you please clear cache and and storage of WhatsApp?
    Did you disable any battery optimization and network restrictions for WhatsApp and grant all necessary permissions?
    Padma.J likes this.
  3. G_plusone
    Nougat Nov 17, 2021
    Padma.J likes this.
  4. Padma.J
    Eclair Nov 17, 2021
    G_plusone and Dresa91 like this.
  5. Padma.J
    Eclair Nov 21, 2021
    Padma.J , via OnePlus 9 Pro , Nov 21, 2021 :
    Some times Iam not receiving incoming calls and not able to do out going calls also . incoming callers complaining that my mobile is switched off .today same thing happened then I switched off my mobile then it started working .I already changed my sim because faced same problem while using old sim in OnePlus 7t.I have to change any settings ??
  6. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Nov 21, 2021
    Dresa91 , Nov 21, 2021 :
    Did you reset your network settings?
  7. Padma.J
    Eclair Nov 21, 2021
  8. Padma.J
    Eclair Nov 21, 2021
  9. Dresa91
  10. Padma.J
    Eclair Nov 21, 2021
  11. Dresa91
  12. Padma.J
    Eclair Nov 23, 2021
    Padma.J , via OnePlus 9 Pro , Nov 23, 2021 :
    On 22nd n 23rd morning I tried to check whether any calling issues are there.then I come to know my mobile is not able to make calls r receive calls .then I switched off and on after that's it started working .I will update after two days if same problem occurs.
    Dresa91 likes this.
  13. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Nov 23, 2021
    Dresa91 , Nov 23, 2021 :
    okay:)
  14. rashukp
    Cupcake Nov 23, 2021
  15. Padma.J
    Eclair Dec 1, 2021
    Padma.J , via OnePlus 9 Pro , Dec 1, 2021 :
    Hi today again (after one week) faced incoming and outgoing issues then I switched off and on like before . OnePlus phones are having some software problems
  16. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Dec 1, 2021
    Dresa91 , Dec 1, 2021 :
    what OxygenOS version are you using?
  17. Padma.J
    Eclair Dec 1, 2021
  18. Dresa91
  19. Padma.J
    Eclair Dec 1, 2021
  20. Dresa91
    go to settings and check for updates
