2
OnePlus 9 Pro flicker issue via OnePlus 6
  1. SaiKalyan999
    Eclair Apr 23, 2021
    SaiKalyan999 , via OnePlus 6 , Apr 23, 2021 :
    I'm having this where my phone keeps flickering every 3~4 seconds, it becomes unusable and holding the power button for hard reboot doesn't happen right away. This issue seem to happen to me about 10 times now! Is this a software bug or a hardware bug?
    PhotoPicker and AleMart94 like this.
  2. itsFreelancer
    Honeycomb Apr 23, 2021
    itsFreelancer , via OnePlus 9 Pro , Apr 23, 2021 :
    Scared the living shit out of me. My phone is less than a week old and it started just a few minutes ago. Out of nowhere. I was watching Netflix. Had to lock the screen. Came to unlock and boom, static screen flickering. Holding down power button didn't help or maybe I did it wrong. Tried holding down power button and volume up button and the phone restarted. will see if this occurs again. Really hope it's a software issue.
    JoeXC likes this.
  3. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 23, 2021
  4. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 23, 2021 :
    Could very well be a software issue, but if it's very common for you I would not hold my breath but see if I could get it replaced to see if you get rid of the problem. In my case it could possibly be solved by a quick swap at my local reseller in town.
    I'm a pretty heavy user and it has never happened for me.
    Caoimhín likes this.
  5. itsFreelancer
    I'm going to wait a couple of more days and see how it goes. Probably do a clean wipe if it happens once more. Sent a bug report already. According to users complaints, it happens when the screen wakes up.
  6. McLarenMania
    Gingerbread Apr 23, 2021
  7. AleMart94
    Donut Apr 23, 2021
    JoeXC likes this.
  8. #8
  9. #9
  10. SaiKalyan999
    Eclair Apr 23, 2021
    Do you also have the issue such as if you pause the video it will play automatically? I observed that on YouTube, Netflix etc
    vipulkumar7200 likes this.
  11. SaiKalyan999
    Eclair Apr 23, 2021
  12. The.Passenger.
    Eclair Apr 26, 2021
    The.Passenger. , Apr 26, 2021 :
    I had the same flicker issue while watching Netflix. I already replaced it but seems I was a bit to quick in my reaction. Now I'm really sure it's a software bug so keep calm relaxing and still having fun with your 9 pro again!
    Swejuggalo and darkarvan like this.
  13. Swejuggalo
    OnePlus 9 Series Expert Community Expert Apr 27, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 27, 2021 :
    What display settings do you use? And are you using any of the display enhancement options?
    Maybe I could replicate it too.
  14. AbandonedTrolley
    Jelly Bean Apr 27, 2021
  15. The.Passenger.
    Eclair Apr 27, 2021
    The.Passenger. , Apr 27, 2021 :
    I was switching between QHD and FHD while i was watching Netflix, i know Sounds a Bit Strange but i was Interested in the difference between the normal graphic smoothing you can put on in the normal display seetings and the extrem graphic smoothing where you can find in the Oneplus Lab Settings. The extreme graphic smoothing works only in FHD display Resolution, that was the reason why i was switching. And from one second to another the breakdown came and the flicker Starts.
    Swejuggalo likes this.
  16. Swejuggalo
    Sure sounds like a form of driver issue then
  17. Adityaanish
    Cupcake Apr 29, 2021
  18. #18
  19. rv124
    Eclair Apr 29, 2021
  20. bhilbern
    Eclair Apr 29, 2021
    bhilbern , Apr 29, 2021 :
    Is this issue directly connected to Netflix? If so, OP should tell people to not watch Netflix.
