Oneplus 9 Pro full crash and reboot
Do you think this is hardware or software related?
  1. Software
    1 vote(s)
    100.0%
  2. Hardware
    0 vote(s)
    0.0%
  1. joshua_b44_0121
    Cupcake Apr 8, 2021
    joshua_b44_0121 , Apr 8, 2021 :
    Hi this is my first forum post so please forgive if I miss any details.
    So I've had my new Oneplus 9 pro (8GB RAM + 128GB Memory) for about 9 days now and the phone has completely froze on me 4 times, it becomes completely unresponsive for around 10 seconds and then reboots.
    Most recently I was on a google Duo call for around 30mins, but it has done this when I've been using Google Chrome with only a few tabs open, I can't remember what I was doing the other 2 times its happened but I will keep this updated if/when it happens again.
    I want to know if there is anyway to get into the crash reports to see what caused this to happen, I also would like to hear any suggestions from anyone to try prevent this from happening as often.
    I am running Oxygen OS 11.2.2.2LE15BA
    Best regards
  2. the_o2
    OnePlus 9 Series Expert Community Expert Apr 9, 2021
    the_o2 , Apr 9, 2021 :
    Hi, they already released a software update
    https://forums.oneplus.com/threads/oxygenos-11-2-3-3-for-the-oneplus-9-and-oneplus-9-pro.1414383/
    I hope it will fix your issue.
    Meanwhile you can report this bug here if you want
    https://forums.oneplus.com/feedback
    Caoimhín likes this.
  3. Chinaroad
    Honeycomb Apr 9, 2021
    Chinaroad , Apr 9, 2021 :
    Happened to me alot even after 2 factory resets, but i was using the bubble notifications, for messenger for exemple, after disabling it from settings, it didn't happen again
  4. W1617992396325
    Cupcake Apr 10, 2021
    W1617992396325 , Apr 10, 2021 :
    My phone has the exact same issue, reboots at random times (even without using it).
    I just disabled bubble notifications as well to see if that does solve it. Thanks for the suggestion
  5. W1617992396325
    Didn't solve the issue, it's still happening. I created a bug report
  6. Chinaroad
    Honeycomb Apr 10, 2021
    Chinaroad , via OnePlus 9 Pro , Apr 10, 2021 :
    i also did a video and created a bug for them, but they asked for a log, and since it didn't happen again....
  7. W1617992396325
  8. Ruqhaiya Taskeen
    OnePlus Bug Hunter Staff Member Apr 10, 2021
    Ruqhaiya Taskeen , Apr 10, 2021 :
    For analyzing this better we would need few details. It'll be of great help if you could share the information for further analysis. We've responded to you via direct message. 
    Regards,
    Ruqhaiya Taskeen
  9. W1617992396325
    Cupcake Apr 11, 2021
    W1617992396325 , via OnePlus 9 Pro , Apr 11, 2021 :
    Out of interest, are you using Nextcloud on your phone?
    I am (or was) and it was syncing all my photos from Google Drive to my Nextcloud instance. Everytime the phone was rebooting it was also syncing photos to Nextcloud.
    I decided to disable Nextcloud and I went from 3 random reboots per hour to 0 reboots in the last 12 hours.
    Not sure if it has something to do with Nextcloud itself but maybe the continuously reading of the flash that causes locks and in turn will cause the reboot of the phone.
    The reboot I experience doesn't require me to enter my SIM pin but only to use my unlock pattern instead of my fingerprint to unlock, it also says it has been rebooted.
  10. Chinaroad
    Honeycomb Apr 11, 2021
    Chinaroad , via OnePlus 9 Pro , Apr 11, 2021 :
    Nope, i didnt have nextcloud, i just disabled bubbles for all notifications on settings, and it's been a week now since i didnt get a reboot or crash, hope it doesn't comeback after the 15 days are over lol
  11. Vinay Prajapati
    Cupcake Apr 15, 2021
    Vinay Prajapati , via OnePlus 9 Pro , Apr 15, 2021 :
    How did you turn of the bubble notification? Is it like for individual app or only the common one in the notification tab in settings?
  12. Chinaroad
    Honeycomb Apr 15, 2021
    Chinaroad , via OnePlus 9 Pro , Apr 15, 2021 :
    Go settings, then notifications, and at the bottom you'll find bubbles, disable it
  13. Vinay Prajapati
    Cupcake Apr 18, 2021
  14. Damianosss
    Cupcake Apr 19, 2021
