OnePlus 9 pro lag issue via OnePlus 9 Pro
  1. N1600417325693 , via OnePlus 9 Pro , Aug 10, 2021 :
    From past few days the phone is lagging like all the time it's like the frame rate drops from 120 to 60 or even lower.This would usually occur when the phone is heated.But now it's like all the time. I tried force 120hz but still it doesn't work. The only solution is I have to restart every 5min so that it rolls back to 120hz and use it for the next 5 min.Please fix this
    A1618487185646 likes this.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 10, 2021
  3. #3
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 13, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Aug 13, 2021 :
    Are you monitoring the refresh rate via the Developer Option or is it just degraded performance you notice? When?
    The idea I had with the CPU and temperature views via Devcheck is to confirm the system is acting normally. If not even that can affect the frame rate and performance of everything.
    And some apps automatically choose 60 Hz. To decide every app yourself you can use apps like AutoHz. But it does not fix lag and frame drops if that is the problem you are having.
  5. N1600417325693 , via OnePlus 9 Pro , Aug 14, 2021 :
    I am not complaining about apps pushed to 60 hz. I use autohz bit still even the os gets pushed back to 60hz and then even the apps get lowed to 60hz even if I have forced 120 on the autohz
  6. #6
  7. C1629316441953
    Cupcake Aug 19, 2021
  8. S1629588807117
    Cupcake Aug 22, 2021
  9. Niklasg85
    Ice Cream Sandwich Aug 22, 2021
  10. Niklasg85
  11. S1629588807117
    S1629588807117 , via OnePlus 9 , Aug 22, 2021 :
    Nah, i own both oneplus 9 and iphone 11 pro mx for about 2 years now, daily usage with 60hz is decent, doesnt need 120hz tho..iphone never lag , rarely has bugs and get the job done120hz only apply when gaming, but my oneplus 9 got bugs while gaming which affect gameplay very much
  12. #12
  13. W1626585611198
    Cupcake Sep 4, 2021
  14. W1626585611198
    Cupcake Sep 4, 2021
  15. B1633466831051
    Cupcake Oct 26, 2021
    B1633466831051 , via OnePlus 9 Pro , Oct 26, 2021 :
    I got my Pro a few weeks ago and turned off the Ambient display settings since I didn't really need that. Restarted the phone a day later and after turning the screen off the first time, the entire UI started slowing down heavily. I turned the setting back to ON and everything seemed perfectly fine.
    Not sure if this helps, but hopefully it fixes a lot of people's lag issue if they turned off Ambient Display. I reset my phone multiple times and checked every app downloaded to see if they caused it, this was so far the only thing causing lag.
