OnePlus 9 Pro makes strange noises via OnePlus 9 Pro
  1. xxeperxx
    Eclair Jun 20, 2021
    xxeperxx , via OnePlus 9 Pro , Jun 20, 2021 :
    Hello Community.
    I was just lying in bed and my OnePlus 9 Pro slipped out of my hand. It landed on my stomach, was a fall of about six inches. (15 cm)
    Now the smartphone makes strange noises when I move or shake it. It sounds like something is loose. You can also feel that something is shaking inside and out, and it's pretty loud.
    I use protective film and a case
    I'm afraid that something might be broken. Does somebody has any idea?
    translated by google translator
  2. xxeperxx
    Eclair Jun 20, 2021
    I just noticed that the entire picture on the camera has been consumed. The ultra-wide-angle camera in particular causes problems. It's all completely wrong and it's very distorted.
  3. camohan
    Moderator Moderator Jun 20, 2021
    camohan , Jun 20, 2021 :
    Hi there, a image will help to visualize.
  4. xxeperxx
    Eclair Jun 20, 2021
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 20, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Jun 20, 2021 :
    Unless that was a six-pack comparable to a rock hard muscles by extreme training that should be a rather soft landing 😜
    Unless something happened to it at some other point the sounds you hear would be the camera module. Both auto focus and OIS involves moving parts. During shaking they can move by them self's. However you say it sounds even when moving it. Normal movement should not make a sound.
    Sheppards, Caomhin and McJader like this.
  6. xxeperxx
    Eclair Jun 20, 2021
    Yes, I photographed a tablet here, for example. You can clearly see that the picture is distorted. I've also tried the whole thing indoors, but I don't want to post these pictures here.
  7. xxeperxx
    Eclair Jun 20, 2021
    Yes, while the smartphone is moving, you can feel that something is wobbling back and forth
  8. Swejuggalo
    Swejuggalo , Jun 20, 2021 :
    It sounds like something is damaged in the camera module. Falling 15 cm onto your stomach would barely compare to holding it in your hands and shake it once.
    If this drop indeed damaged it I'd would say something must have been defect right from the begining. That small fall should not break anything.
    puccellino likes this.
  9. xxeperxx
    Eclair Jun 20, 2021
    Okay. I'll just wait and see, maybe it'll work by itself again
  10. Swejuggalo
  11. xxeperxx
    Eclair Jun 20, 2021
  12. camohan
    Hi there, it could be OIS (Optical Image Stabilization) module that wobbles and it is normal which happens for other devices too,
    Caomhin likes this.
  13. Swejuggalo
  14. xxeperxx
    Eclair Jun 20, 2021
  15. Swejuggalo
  16. xxeperxx
    Eclair Jun 20, 2021
  17. Swejuggalo
    Found a better one 😉
    If there always is a sound even when moving gently and all photos has become a lot worse and hard to focus on same firmware as before something may have happened.
    Greetings from Sweden.
    xxeperxx likes this.
